Majhong like SDL game
OL
Postby OL » Sat Dec 03, 2016 10:53 am
I have done a small port of Lopan Majhong game
http://gem.lutece.net/download/lopan.zip
Olivier
OL
OL
Re: Majhong like SDL game
Postby OL » Sat Dec 03, 2016 11:15 am
OL wrote:Hello,
Olivier
Just add coldfire version
OL
Orion_
Postby Orion_ » Sat Dec 03, 2016 1:14 pm
I can't make it run on ste, tt or falcon :/
what are the requirements ?
penguin
Postby penguin » Sat Dec 03, 2016 6:40 pm
Orion_ wrote:I can't make it run on ste, tt or falcon :/
It's an SDL port, so requirements are likely higher than for a "native" application. Works with Aranym (picture) and probably Firebee as well.
Since Lopan is pretty much just standard Mahjong Solitaire, I don't think it makes sense on the STE, TT or Falcon as there are already plenty of ports available. Peking works on classic systems but crashes on the Firebee.
AtariUpToDate - Atari ST/TT/Falcon software database and version tracker: http://www.atariuptodate.de
st-computer magazine - https://st-computer.atariuptodate.de/
penguin
Postby penguin » Sat Dec 03, 2016 6:54 pm
OL wrote:Hello,
Olivier
Could you put the links to your two ports (Lopan and MinivMac) on your website as well? The download links will otherwise be hard to find after a while...
OL
Postby OL » Sat Dec 03, 2016 7:41 pm
Need a bit memory, 256 colors or more, 640*400, 68020 minimum, in 256 color load is a bit long at 16Mhz!
Here under Hatari Falcon emulation, 64K resolution is limit but it display, it work too in 256 colors
To be able to run SDL, add in mint.cnf or myaes.cnf
export SDL_VIDEODRIVER=gem
Olivier
OL
OL
Postby OL » Sat Dec 03, 2016 7:44 pm
penguin wrote:
OL wrote:Hello,
Olivier
I know, I was thinking to do something, there is a lot of softtware I shared in the past.
Olivier
OL
jfl
Postby jfl » Sat Dec 03, 2016 9:55 pm
Thanks, Olivier. This works great on the FireBee. And it looks lovely. If you have the time please announce it on the ACP mailing list.
Jean-François
GEMDict – GEMClip
OL
Postby OL » Sat Dec 03, 2016 10:26 pm
penguin wrote:
OL wrote:Hello,
Olivier
Not finished but done:
http://ol.lutece.net
OL
OL
OL
Postby OL » Sun Dec 04, 2016 7:46 pm
Update of archive, the 68000 version is now really a 68000 version (wrong version copied of SDL it was 68020-60)
New version 68020-60 available, small SDL update coldfire version (nothing important).
Source code include
Olivier
OL
OL
Postby OL » Sun Dec 04, 2016 7:47 pm
jfl wrote:Thanks, Olivier. This works great on the FireBee. And it looks lovely. If you have the time please announce it on the ACP mailing list.
Thanks Jean François,
small update of coldfire version
Olivier
OL
jury
Postby jury » Wed Dec 07, 2016 8:48 pm
Tried normal + 2060 versions on CT63 ( @93MHz ) but in TOS mouse is frozen and in MiNT its rather slow to be playable ( mouse works fine )
Did anyone with CT'ed Falcon has any success with this game or its rather for more powerful machines?
jfl
Postby jfl » Thu Dec 08, 2016 9:36 am
jury wrote:Tried normal + 2060 versions on CT63 ( @93MHz ) but in TOS mouse is frozen and in MiNT its rather slow to be playable ( mouse works fine )
This is really strange because on the FireBee the game is very fast and I wouldn't think a 'Bee is that much faster than a Falcon060. Must be something other that the hardware.
Jean-François
GEMDict – GEMClip
jury
Postby jury » Fri Dec 09, 2016 8:08 am
jfl wrote:Must be something other that the hardware.
Will check it more this weekend on other games, but I doubt its software related, as it is quite fresh install of Easymint 1.9 just with Jinnee replaced with latest Teradesk and NVDI in auto folder. Nothing more on my current software setup.
As with TOS, the mouse in this game is completely frozen. Did anybody with CT6x run it fine in TOS?
fidzen
Postby fidzen » Fri Dec 09, 2016 4:35 pm
Hi.
I have tested it with different configs and I found this result on my Falcon.
CT63+SV+TOS: Both versions works fine and are fast.
CT63+TOS: Both versions freezes the mouse at startup.
CT63+SV+EasyMINT 1.9: Both versions are slower and the mouse freezes after some seconds of playing.
Atari 2600 4-switch Woody
OL
Postby OL » Fri Dec 09, 2016 7:01 pm
fidzen wrote:Hi.
I'm working on an update of it, should use far less power.
Strange for mouse freeze, I never test it under TOS always with Mint, I would like be able to run it correctly under Falcon 16Mhz, there is a little bit work ;-)
OL
OL
vido
Postby vido » Fri Dec 09, 2016 7:17 pm
On my FireBee under MiNT the game works just great.
Thanks Olivier!
OL
Postby OL » Fri Dec 09, 2016 7:52 pm
fidzen wrote:Hi.
I think this software should be far faster in true colore or near true color than in 256 color
Olivier
OL
jury
Postby jury » Sat Dec 10, 2016 4:24 pm
fidzen wrote:Hi.
Great. Thanks for the test!
I have SV but on my new setup still not installed, so this should be enough solution for me :)
OL wrote:I'm working on an update of it, should use far less power.
Cool! :)
OL
Postby OL » Tue Dec 13, 2016 6:25 am
jury wrote:
fidzen wrote:Hi.
Cool! :)
For the moment no update, but I can said this:
- High reduce of load under Mint OK
- Select a card under Falcon 16Mhz is done at correct speed OK
- Second card removing still very very slow, more difficult to fix, I think it work on computer with fast ram, a lot of redraw, this is why it is so slow.
Olivier
OL
OL
Postby OL » Sat Dec 17, 2016 8:25 pm
fidzen wrote:Hi.
Hello
I have updated the archive:
- High reduce of the system load under multitask system
- Select first card is now very fast
- Select the second card is twice faster than before (still around 6 seconds under Falcon 16Mhz :-( )
- Start speed near no change
It have been tested under Mint 1.19 + MyAES Aranym and Hatari Falcon Mode
Best Regards
Olivier
OL
OL
Postby OL » Sun Dec 18, 2016 10:39 am
Crash report I remove it in download.
and try to find what wrong I have done.
Olivier
OL wrote:
fidzen wrote:Hi.
Hello
Best Regards
Olivier
OL
OL
Postby OL » Mon Dec 19, 2016 5:04 pm
Ok looks crash was link to configuration in xbios mode while I test only in GEM mode
So now by default driver used is GEM, if you want to use xbios driver it is still possible adding environment value
export SDL_VIDEODRIVER=xbios
But I think GEM driver is far enough for this game!
Olivier
OL wrote:Crash report I remove it in download.
Olivier
OL wrote:
fidzen wrote:Hi.
Hello
Best Regards
Olivier
OL
vido
Postby vido » Mon Dec 19, 2016 6:53 pm
Thank you Olivier!
But I did just a quick test on my FireBee and V4e version is unplayable while the older version works just fine.
The game starts but then you can not click on the tile ESC, F1 ,F2, F3, Return key just dont work.
Also TERM signal doesnt close the game and the KILL signal takes about a minute to game is killed.
But I had no time to do more tests.
OL
Postby OL » Mon Dec 19, 2016 7:22 pm
vido wrote:Thank you Olivier!
In the previous version you were running with SDL_VIDEODRIVER=gem ?
I'm going to try with XaAES if I can start it
Olivier
OL
Return to “Games”
