Street Art, Japan Beauties... 4Mo STe demos
DataPro
Postby DataPro » Wed Jul 15, 2015 3:11 pm
I try to make Street Art, Japan Beauties and STrangeRobots work on my 520STe with 4MB RAM
STrange Robots and Japan Beauties crashes.
Street Art works but there are glitches and a lot of pixel errors.
I use disk-images from Pouêt with several disquette written on several PC...
Is my ST has a problem ?
Others games and demo are working fine...
Is it a RAM issue ?
I will try to find some other 1Mb SIMM.
Cyg
Re: Street Art, Japan Beauties... 4Mo STe demos
Postby Cyg » Wed Jul 15, 2015 8:31 pm
Hi Datapro, here the customer service :-)
First of all I am sorry you spent so much time to make my demo work.
At first I would think about the TOS, would you have the chance to try TOS 2.06 UK ?
About the graphic glitchs, it can happen sometimes on some configuration, it's about the wake up states value. Turn off your ST for 5-10 seconds and try again.
I have fixed my algorithm regarding this issue for the next release(s), until that no way, this bug could also happen on any demo of the kind (fast synchronized palette changes)
Best regards,
Cyg
Thx to mOdmate for the link forward.
DataPro
Postby DataPro » Thu Jul 16, 2015 1:33 pm
Hello and thanks for your demos ! :cheers:
Don't be sorry. I know that it's not always easy with old machine.
I think also that Atari ST is very reliable.
I have the same issue with the vertical picture at the beginning of 20 years STE.
I spent time on Atari STe demos because next Saturday, there a retrocomputing event and I will show what an Atari STe is capable of !
I only have an old Atari SH205 but I don't use it very often because it's very noisy.
So, I use PC computers to write ST disks.
I don't have any machine with TOS 2.06
I am French and I use TOS 1.62FR
I have a TOS 2.0X on disk. Maybe I could give it a try.
Cyg
Postby Cyg » Thu Jul 16, 2015 7:34 pm
Salut,
J'espère que tu arriveras à les faire tourner pour le retro computing alors ! C'est pas pour l'AC Retro Gaming dans le 77 ?
As-tu le même problème avec STrange Robots : http://www.pouet.net/prod.php?which=62142
Y'avait aussi le player vidéo qui fonctionne un peu différement mais il faut mettre les vidéos sur un disque rapide : http://www.pouet.net/prod.php?which=63527
Au plaisir,
Cyg / Fabrice
DataPro
Postby DataPro » Fri Jul 17, 2015 12:26 pm
Bonjour,
Non c'est pour les infoticaires demain dans le 58.
Strange Robots crashe au démarrage de la démo.
Je vais essayer de changer la RAM. Pour l'instant je suis redescendu à 2Mo.
Return to “Demos”
