How to enquire Maddalt() support
GFA, ASM, STOS, ...
Arne
Postby Arne » Mon Dec 02, 2019 1:16 pm
what is the clean(est) way to check if the OS is supporting Maddalt() calls?
Shall I check if GEMDOS version is >= 0.19 or is there a better way?
Thanks, Arne
ThorstenOtto
Re: How to enquire Maddalt() support
Postby ThorstenOtto » Mon Dec 02, 2019 3:05 pm
GEMDOS functions that aren't available return -32, so just check for that. But where are you calling Maddalt()? I'm not sure whether that will be too late when done from a auto-folder-program or similar.
Postby joska » Mon Dec 02, 2019 3:14 pm
Maddalt() can be called at any time.
Arne
Postby Arne » Mon Dec 02, 2019 3:19 pm
ThorstenOtto wrote:GEMDOS functions that aren't available return -32, so just check for that. But where are you calling Maddalt()? I'm not sure whether that will be too late when done from a auto-folder-program or similar.
Thanks. Will check for -32 then.
AUTO folder is the preferred way.
Return to “Coding”
