STing Driver coding
GFA, ASM, STOS, ...
Arne
STing Driver coding
Postby Arne » Mon Mar 20, 2017 7:57 am
Folks,
I got a question regarding on how-to program a driver for STing.
I think (!) that the driver which accesses the hardware is this STX file. Right or wrong?
Is there a How-To with demo code that driver?
Thanx, Arne
Re: STing Driver coding
Postby mikro » Mon Mar 20, 2017 9:05 am
Which STX file?
Anyway, if you're targeting something else than bare ST, I'd advise to look into FreeMiNT drivers instead and before you ask, yes it does have an example driver included: https://github.com/freemint/freemint/bl ... dummyeth.c ;)
Arne
Postby Arne » Mon Mar 20, 2017 9:15 am
mikro wrote:Anyway, if you're targeting something else than bare ST
No, I am asking only for STing - nothing else.
Postby simonsunnyboy » Tue Mar 21, 2017 4:45 pm
I am totally unaware of Sting driver internal documentation. However the STIK API is the one Sting does provide to applications.
Maybe it is easier to write a custom driver outside of Sting that conforms to providing the STIK API by itself?
Postby czietz » Tue Mar 21, 2017 6:13 pm
Not exactly a demo driver, but Thomas Redelsberger's Ethernet driver for STinG comes with full source code -- mostly in assembler though. It is still available via the Internet Archive: http://web.archive.org/web/201604291704 ... /index.htm
EDIT: Oh, and with Google I just found this: http://www.mbernstein.de/atari/prog/infos/sting/ -- a German guide on the STinG API that says it also covers STX module programming.
Arne
Postby Arne » Wed Mar 22, 2017 11:57 am
czietz wrote:EDIT: Oh, and with Google I just found this: http://www.mbernstein.de/atari/prog/infos/sting/ -- a German guide on the STinG API that says it also covers STX module programming.
Found that, too. Unfortunately just translation of the information about data structures in STING.HYP itself.
Anyway: I found the sources of STing here on the forum. Pretty ugly C code (with errors) but ASM is nicely documented.
Return to “Coding”
