ijor wrote:I know you are not talking about EmuTOS. I am talking about the archive referenced by the OP at the first post in this thread. Some files in the archive are original Atari. Some seems not.
troed wrote:Indeed. I think we need someone to explain what this archive really contains rather than guessing.
$ fgrep -R EmuTOS *
aes/crysbind.h: * 2002-2016 The EmuTOS development team
aes/gemwmlib.c: * 2002-2016 The EmuTOS development team
aes/gsxdefs.h: * Copyright (C) 2016 The EmuTOS development team
aes/struct88.h: * 2002-2016 The EmuTOS development team
alcyon/include/mint/cookie.h:#define C__CF_ 0x5F43465FL /* ColdFire, set by FireTOS and EmuTOS */
bios/startup.S: * startup.S - EmuTOS startup module
bios/startup.S: * Copyright (C) 2001-2016 by the EmuTOS development team
bios/tosvars.h: * Copyright (C) 2001-2016 The EmuTOS development team
common/asmdefs.h: * Copyright (C) 2001-2015 The EmuTOS development team
common/ctrycodes.h: * Copyright (C) 2003-2016 The EmuTOS development team
common/rom.ld: * based on linker script from EmuTOS
common/rom.ld: * Copyright (C) 2016 The EmuTOS development team
common/tosvars.S: * Copyright (c) 2005-2013 by the EmuTOS development team.
* Revision Control System
* $Author: mui $ $Date: 89/04/26 18:29:04 $
* Revision 2.2 89/04/26 18:29:04 mui
* TT
* Revision 2.1 89/02/22 05:02:47 kbad
* *** TOS 1.4 FINAL RELEASE VERSION ***
* Revision 1.5 89/02/16 18:01:27 kbad
* Moved M132 define here from flavor.h
* Revision 1.4 88/09/08 18:52:58 kbad
* Moved build-specific stuff to flavor.h
* Revision 1.3 88/08/02 13:02:49 kbad
* Set with parameters of 1.04d 8/1/88 build
* add DENMARK, fix NORWAY, FINLAND
* Revision 1.2 88/07/15 16:07:50 mui
* add flag DOWARNING to do AES startup alert box
* Revision 1.1 88/06/02 12:35:52 lozben
* Initial revision
/* MACHINE.H 09/29/84 - 10/09/84 Lee Lorenzen
* for 68k 10/10/84 - 04/22/85 Lowell Webster
* Update 05/07/85 Derek Mui
* Add more define 07/12/85 Derek Mui
* add MULRES 3/25/86 Derek Mui
* add SWISSGER & SWISSFRA defines 8/3/87 Slavik Lozben
* add MEXICO defines 9/28/87 Slavik Lozben
* Clean up 11/23/87 Derek Mui
* Added 132 column switch 12/18/87 D.Mui
* add FINLAND 1/8/88 D.Mui
1st1 wrote:To me this does not look like EmuTOS.
BlankVector wrote:So please, let's top speaking about EmuTOS here.
troed wrote:BlankVector wrote:So please, let's top speaking about EmuTOS here.
While you are absolutely correct, of course, with regards to GPL and distribution of any binaries - I'm sorry to say that you cannot tell the rest of us to stop talking about something
The true authors are of course free to stand up.
/Troed
BlankVector wrote:I didn't look at that archive, I don't care about Atari Corp stuff.
This stuff is completely unrelated to EmuTOS.
AtariZoll wrote:@Crashman: if you really want Spanich TOS 2.06 (and 3.06), you can go my way - I did translation of TOS 2.06 to Serbian somewhere in 1993. As base is best to get German TOS, simply because txt. messages are usually longest in German. With some good Hex editor you need only to replace original txt to translated, taking care to not exceed original length, and proper termination (with 0). may add some extra spaces in middle to keep formatting better.
ijor wrote:Why you react like that???
ijor wrote:Is it really the original Atari source tree? I see some files say copyright EmuTOS team ???
troed wrote:I think this is a hacked together distribution of genuine TOS source code, decompiled TOS code merged with more recent developments from, amongst others, EmuTOS
AtariZoll wrote:This mixture is very questionable how will work
AtariZoll wrote:Serious people would add some notes, guides to how compile. I don't see anything of it.
AtariZoll wrote:Yes, translating RSC is possible with RSC editor, and in TOS there is regular RSC structure, so can extract it and edit
AtariZoll wrote:GemDOS is only German.
AtariZoll wrote:only AES has diverse language versions.
mikro wrote:most likely you not only don't get a valid translation of given TOS version but most likely you risk losing data or experiencing crashes.
