Pulling printer port lines low
Foxie
Postby Foxie » Tue Jan 23, 2018 2:21 pm
The datasheet for the Yamaha sound chip is extremely sketchy. I assume since it says it's NMOS it should be safe to pull the lines low externally when set to outputs? It looks like it can't source any real current - but that's no guarantee that it won't get damaged when grounded. If it's really NMOS I can't see how it could get damaged. But the MFP has totem-pole outputs so who's to say the Yamaha chip doesn't? I know it's possible to set the pins as inputs. I'm wondering about what happens if you don't.
I know there are joystick to printer port adaptors, which surely wouldn't be safe if shorting the outputs wasn't allowed.
I know many other systems use open collector outputs on their printer ports. The Amiga for example, and earlier IBMs. Then, later IBM clones started using totem pole outputs for EPP/ECP stuff which made it dangerous to pull the lines low.
It also looks like the maximum sink current is 1.6mA, so I'd need to use 3.3k pull-ups at minimum. I've heard of some printers overheating the sound chip - probably because they used lower value pull-ups?
I wonder if the Firebee has the same electrical specs for its printer port?
Update: it looks like it should be safe to pull the lines low. The SMP24 driver for Cubase does a write cycle, sets the port as an input and then does a read. It finally acknowledges the read by pulsing strobe. So there is a moment in time where the SMP24 is driving PORTB with it set to outputs.
krupkaj
Re: Pulling printer port lines low
Postby krupkaj » Sun Feb 11, 2018 11:37 pm
What I remember when using old PARCP, Petr recommended to set the parallel port to input. There is PAR_IN.prg in the PARCP package.
