Atari Mega STe MIDI to USB instrument
TechCowboy
Postby TechCowboy » Tue Jan 09, 2018 5:07 am
Tried to google search this, but maybe my search terms were poor.
My celviano piano keyboard has a female USB B (host) connection
The Atari, of course, the 5 Pin DIN connector
Is there a device that will allow me to connect these together?
The keyboard came with a standard printer cable (male USB B to male USB A)
I see lots of PC (male USB A) -> MIDI 5 pin DIN, such as this,
https://www.bestbuy.ca/en-ca/product/ro ... 65566.aspx
but I don't know if just using a "gender bender" adapter to convert the male USB A connect to a female USB A would work.
Anyone know or have a solution?
spiny
Disk Imager Supreme
Disk Imager Supreme
Re: Atari Mega STe MIDI to USB instrument
Postby spiny » Tue Jan 09, 2018 11:14 am
your post on the FB group is probably the best solution - using the RaspPi.
Foxie
Postby Foxie » Tue Jan 09, 2018 12:49 pm
TechCowboy wrote:Is there a device that will allow me to connect these together?
Yes, there is!
This is exactly what you're looking for, I believe: http://www.kentonuk.com/products/items/ ... host.shtml
I should also add that a gender bender definitely won't work. You might even blow it up. You need a device specifically made for this type of connection.
1st1
Postby 1st1 » Tue Jan 09, 2018 3:07 pm
Atari Mega STE and TT will soon habe Lightning USB interface. There is also NetUSBee with USB interface and something for ACSI-DMA-port with USB. There must be a skilled software programmer which could make a CUBASE driver for that...????
TechCowboy
Postby TechCowboy » Fri Jan 26, 2018 6:12 pm
