FALCON030 New or Secondhand keyboard.
RPCGAMES
Postby RPCGAMES » Tue Dec 26, 2017 3:18 am
Hi Guys, Do you guys have a second hand keyboard for the Atari Falcon030?
Our keyboards RETURN key and 0 key on the keypad don't work.
We're programming Centron3D for Falcon030 at the moment and pressing the ENTER key on the keypad
is the only solution cos the RETURN key doesn't work.
I also herd that an Atari ST keyboard will work as well.
Please let me know. Thanks guys and Merry Christmas to all.
Pete
CEO / RPC-GAMES!
Re: FALCON030 New or Secondhand keyboard.
Postby wongck » Tue Dec 26, 2017 4:43 am
Yes, the Atari ST keyboards will work on the Falcon.
alexh
Postby alexh » Tue Dec 26, 2017 1:30 pm
Get an ST keyboard and gently swap the keys
RPCGAMES
Postby RPCGAMES » Tue Dec 26, 2017 9:22 pm
Thanks guys, I'll hunt for a Atari ST keyboard. If you know of any please let me know and I'll purchase it from you.
Pete
CEO / RPC-GAMES!
fidzen
Postby fidzen » Tue Dec 26, 2017 10:21 pm
RPCGAMES wrote:Hi Guys, Do you guys have a second hand keyboard for the Atari Falcon030?
Pete
CEO / RPC-GAMES!
If the keys doesn't work it most likely needs a good clean.
I have disassembled two Falcon keyboard and cleaned all the contact surfaces under each key.
Works like a charm after that.
Atari 2600 4-switch Woody
1024MAK
Postby 1024MAK » Thu Dec 28, 2017 4:42 am
Yeah, the first step is to take it apart (take some photos as you go if you are not likely to remember how it comes apart). Then clean the gunk and dirt off. Let everything dry, the reassemble and test it again.
It is also possible that there may be a dry joint or two on the keyboard PCB. Or, if the micro controller is in a socket, that it needs pressing firmly back into it's socket.
Mark
RPCGAMES
Postby RPCGAMES » Wed Jan 10, 2018 7:24 am
Thanks for the info guys. I'll take our keyboard apart and give it a good clean. I'll try the Keyboard controller too. If it's still faulty then I'll buy an ST keyboard. :)
Pete :)
