Multi-colored bars on startup
fletch15
Postby fletch15 » Sun Dec 17, 2017 11:23 pm
Hi. I am new to the forum and recently acquired an Atari ST. When I turn it on I get multi-colored vertical bars (see picture) which won't go away. Anyone any ideas what the problem may be? Thanks for any help.
charles
Re: Multi-colored bars on startup
Postby charles » Mon Dec 18, 2017 1:59 am
beautiful art!!!! : )
atari is my lifestyle,not a hobby.
HOLD ON ! ! !,
Im printing unreadable characters ...!
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Mon Dec 18, 2017 8:27 am
I had an ST with a similar fault and that turned out to be a bad shifter chip. The shifter is the chip inside the 'metal box' on the motherboard, if yours is socketed, check it's secure, could be an easy fix :)
fletch15
Postby fletch15 » Mon Dec 18, 2017 9:21 am
Thanks spiny. I will check and let you know.
Postby joska » Mon Dec 18, 2017 9:42 am
Is there any disk drive activity when you power on?
fletch15
Postby fletch15 » Mon Dec 18, 2017 10:12 pm
There is no internal drive as it is an early 520ST
Postby joska » Tue Dec 19, 2017 12:20 pm
You don't have any floppy drives connected? It would be interesting to know if the ST continues to boot despite the screen image.
jonathanm
Postby jonathanm » Thu Jan 18, 2018 10:47 am
I agree with Spiny, I have heard of this fault before being the shifter chip. Re-seating the chip can sometimes solve it (if, as already mentioned, it is socketed). If it's an early 520ST then I'm guessing there's no composite output (to a TV) that you can also test with?
charles
Postby charles » Thu Jan 18, 2018 11:44 pm
use a small safety pin bent to lightly scratch thru any oxidized pins and terminals on the shifter and shilter socket
I feel whatever lead chrome tim aluminum they comprised the ic socket from probally has built a tid bit of resistance over the years
HOLD ON ! ! !,
charles
Postby charles » Thu Jan 18, 2018 11:45 pm
but on the over hand , might be a vertical sync issue
HOLD ON ! ! !,
