Funky 1024 STE
Bikerbob
Funky 1024 STE
Postby Bikerbob » Tue Nov 21, 2017 6:36 pm
Hello all,
Buddy has a 1040ste - thing is mint.. looks barely used.
Had stock PSU and was getting VERY HOT - after so much time, disk access and directories were getting messed up. We thought bad psu.
So we swapped it out for an ATX wired up to fit the header. Power is not the issue.
After a couple of hours the same thing happens nothing hot, but the disk gets messed up and also the sound dies off to just barely audible with it up full volume.. but you do hear something.
Any ideas? think a diag cart would help here?
Open to suggestions.
James
Atarieterno
Re: Funky 1024 STE
Postby Atarieterno » Tue Nov 21, 2017 7:02 pm
Maybe your ATX PSU is not the problem, but I would try a good PSU:
https://www.facebook.com/centuriontech.eu/
https://www.exxoshost.co.uk/atari/last/storenew/
Re: Funky 1024 STE
Postby joska » Tue Nov 21, 2017 7:06 pm
PSU is clearly not the problem here.
Bikerbob
Re: Funky 1024 STE
Postby Bikerbob » Sat Nov 25, 2017 3:32 am
Do you have a suggestion joska? This machine because it runs pretty well for the most part, might really be easy to solve with a diag cart no???
James
Greenious
Re: Funky 1024 STE
Postby Greenious » Sat Nov 25, 2017 3:52 am
Seems like DMA problems.
Exxos has researched this topic extensively. There are numerous threads about it.
tl;dr swapping the CPU for a HCMOS version will likely do the trick. (alternatives expensive/cumbersome).
You can likely get a MC68HC000 cpu off ebay or similar platform for less than $10, and it is an easy swap.
viewtopic.php?t=5040
1st1
Re: Funky 1024 STE
Postby 1st1 » Sat Nov 25, 2017 7:18 am
What is a 1024 STE?
bishopco3
Re: Funky 1024 STE
Postby bishopco3 » Sat Nov 25, 2017 7:49 am
Atari 1040 STE, indicated in the first post.
Bikerbob
Re: Funky 1024 STE
Postby Bikerbob » Sat Nov 25, 2017 1:11 pm
1st1 wrote:What is a 1024 STE?
Sorry, must have been thinking about RAM 1024
My bad..
James
Bikerbob
Re: Funky 1024 STE
Postby Bikerbob » Sat Nov 25, 2017 1:12 pm
Greenious wrote:Seems like DMA problems.
OK, will look into that, I have the link for Exxos stuff, I am also posting on his forum as well, but a $10 cpu is worth a try.
So no one thinks this sounds like a bad Yamaha chip eh? because the floppy signals go through the Yamaha, and then the later issues with sound????
James
Maeke
Re: Funky 1024 STE
Postby Maeke » Sat Nov 25, 2017 4:16 pm
the floppy signals go through the dma, only the drive selection goes through the yamaha if i'm not wrong.
1st1
Re: Funky 1024 STE
Postby 1st1 » Sun Nov 26, 2017 9:30 pm
My bad..
James
That's true, but it always was 1040, or as prototype also 2080 and 4160, also STE. But you are not alone, when I talk to peoples which had an ST long ago, I often hear 1024 ST. But as a real Atari fan, hearing or reading this makes some pain...
