pcb schematics for eiffel 3
alienkidmj12
Postby alienkidmj12 » Thu Oct 12, 2017 12:08 pm
anyone have these available ?
alienkidmj12
Re: pcb schematics for eiffel 3
Postby alienkidmj12 » Thu Oct 12, 2017 2:30 pm
anyone know if the can to coldfire on eiffel 3 has any use ?
olivierg
Postby olivierg » Fri Oct 13, 2017 9:48 am
End of this page: http://didierm.pagesperso-orange.fr/eiffel.htm
Answer: Why do you need? ? for mouse or keyboard or booth ?
For mouse, is not good idea PS2 is end of life, other free project using USB mouse exist.
Olivier
TT030 4/32 TOS 3.06 SCSI2SD 5.x HD, Mega STE 4Mb TOS 2.06 DD, Mega ST4 DD miniCosmosEX, Mega ST2 DD, 1040 STE DD, 2 x 1040STFM DD, 2 x 1040STF, MegaFile 30, Lynx 1
frank.lukas
Postby frank.lukas » Fri Oct 13, 2017 10:37 am
Fujiyama
Postby Fujiyama » Fri Oct 13, 2017 11:12 am
Very promising, if they'd only add USB keyboard support too....
Are you a good person?
frank.lukas
Postby frank.lukas » Fri Oct 13, 2017 11:29 am
I think Mouse only ...
Great are Wireless USB Mouse.
Fujiyama
Postby Fujiyama » Fri Oct 13, 2017 12:58 pm
Yes, it's mouse only, but in the comments section I asked about keyboard support and the author of the SmallyMouse2 project replied that it's mostly a matter of interfacing it to the computer:
The advantage of quadrature mice is that, although the connectors are not standard, the output to the retro computer is, therefore it’s possible to make a universal adapter such as SmallyMouse2.
Keyboards are another issue entirely. Whilst the USB hardware of SmallyMouse2 is quite capable of interfacing to a USB keyboard; the real issue is the interface to the retro computer. They all use different keyboard layouts and different interfaces. Furthermore, to support a ‘scanned matrix’ style of keyboard (common in many machines) you need something like a crosspoint switch IC to emulate the matrix.
That’s the long answer, the short one is ‘not really practical’
Obviously the author doesn't have the time to create an interface solution for every vintage computer there is out there, but maybe someone here could look into that part?
olivierg
Postby olivierg » Fri Oct 13, 2017 2:14 pm
I have tested the smallyMouse 2 and create PCB (30x18.7mm) with minimum component and directly output to ATARI.
The small size of PCB can be place under 260/520/1040 and MegaST keyboard.
I have tested with this mouse:
Logitech RX250 (Wired)
Logitech M100 (Wired)
Logitech B100 (Wired)
Logitech M105 (Wired)
Logitech M187 (Wireless)
Logitech M185 (Wireless)
The AVR MCU (AT90USB1287) as only one USB input, but maybe with IC USB Hub can add other USB port.
The MCU as 128K Flash and under 3K is used.
(I try my prototype with external usb hub to night).
I am not programmer in AVR Studio, but it's probably possible to add Keyboard option.
Olivier
Fujiyama
Postby Fujiyama » Fri Oct 13, 2017 5:01 pm
Did you order a PCB out of the KiCAD files in the SmallyMouse2 package or modify it and make your own design?
Regardless, that's cool (especially considering you need to solder SMD components)!
About USB hubs the author wrote this further down in the comments section:
You (and anyone else) are more than welcome to use and build upon the project – that’s the beauty of open designs. I do intend to look into the issue of keyboard support myself (no fixed time line though at the moment).
I’m not sure about LUFA support for hubs (LUFA is the underlying USB library I’m using) – If I get some time I’ll set up a test and find out what happens. SmallyMouse2 supports serial debugging; so it’s a good platform for such experimentation.
olivierg
Postby olivierg » Fri Oct 13, 2017 7:28 pm
I have create new design for reduce the size and fit in ST.
PCB Prototype:
I waiting the final PCB with small correction, i replace the JTAG connector and the USB connector is retracted for correct placement in 260/520/1040 with wired mouse.
Olivier
Fujiyama
Postby Fujiyama » Fri Oct 13, 2017 7:48 pm
Very impressive!!!
Fujiyama
Postby Fujiyama » Tue Oct 17, 2017 1:49 pm
Something which might be of interest....
Although for the Amiga, this SUM USB-HID interface could perhaps be adapted for use with the Atari ST? Maybe the author can be asked.
Then there's the open source AmigaInputToUSB project which allows (among other things) Atari joysticks to be used as USB HID devices. Since the joystick connector is a part of the Atari ST keyboard this could be of interest when using a USB keyboard and mouse.
frank.lukas
Postby frank.lukas » Tue Oct 17, 2017 3:16 pm
For a USB Keyboard you need an Chip with USB and serial connections ...
Fujiyama
Postby Fujiyama » Thu Oct 26, 2017 1:07 pm
I contacted the author of the Amiga "SUM" ISB HID interface asking if he'd consider creating an Atari ST version. He's replied asking about the Atari ST key codes and transmission protocol. I don't know much about that -perhaps someone here knows where I can find this info which I can convey to him?
olivierg
Postby olivierg » Thu Nov 02, 2017 8:49 pm
Hi all,
i have finish the Smallymouse 2:
With printed box:
Tested with TT, Mega ST and 1040ST.
Olivier
Postby Cyprian » Thu Nov 02, 2017 9:20 pm
nice job Olivier.
What about price?
olivierg
Postby olivierg » Thu Nov 02, 2017 10:49 pm
The price is 20 euro + shipping:
More informations and products: http://www.gossuin.be/index.php/shop
Olivier
Postby wongck » Thu Nov 02, 2017 10:58 pm
Wow, This is great !!
I wish I knew of it earlier, u ship only to few countries.
davemacblack
Postby davemacblack » Fri Nov 03, 2017 11:34 am
Amazing, it looks great !!!
frank.lukas
Postby frank.lukas » Fri Nov 03, 2017 12:15 pm
Great Stuff, I order one ...
TheNameOfTheGame
Postby TheNameOfTheGame » Fri Nov 03, 2017 3:53 pm
Ah, no shipping to United States? This looks amazing!
olivierg
Postby olivierg » Fri Nov 03, 2017 10:57 pm
I have updated the shipping list.
Olivier
dimfil
Postby dimfil » Sun Nov 26, 2017 8:22 pm
I am interested in buying a Smallymouse2 from Olivier.
I just need a confirmation that it works in a Falcon. I cannot find a reason why it wouldn't, but a confirmation from a Falcon user or someone that has an opinion on that would be helpful.
Postby wongck » Mon Nov 27, 2017 10:01 am
I just received 2 of these from Olivier. He sent them out very fast, postage stamp was on Friday and I received on Wednesday. Of course it was within EU.
I have now used it on my Falcon ( CT63 with ATI ) and in general it works. I am using a logitech M100 mouse, only spare one I have.
It will track your movement up to moderate speed. If you move left or right quickly, it will loose tracking BUT resume back once you slow down without jumping off the spot where it has problem tracking your movement.
So in general YES it works.
Not sure if it is a mouse issue or not but the mouse works well on my windoze notebook even if I move quickly left and right.
Overall I am happy with it, I don't really do quick movement as I do not play games on my Atari.
I think you will be shot in FPS as it cannot react to quick movement.
frank.lukas
Postby frank.lukas » Mon Nov 27, 2017 11:17 am
My Logitech Wireless M185 is working fine ...
