1040 STFM no floppy icons / Desktop appears immediately
Chandler
Postby Chandler » Tue Oct 03, 2017 7:56 pm
I have a 1040 STFM with a problem i haven't seen before
When i switch it on the desktop appears almost immediately, no delay from TOS or floppy drive noises
When the desktop appears there are no floppy icons
So far i've swapped the drive for a known working drive, changed the grey ribbon cable, change the floppy IC, changed the DMA and changed the Yamaha chip
Still the same
Has anyone else seen this before or have any idea what it could be? :)
Arne
Re: 1040 STFM no floppy icons / Desktop appears immediately
Postby Arne » Wed Oct 04, 2017 7:00 am
Get schematics, and check DriveSelect0 and SideSelect coming from the PSG.
Your drive is jumpered for Drive0?
You use TOS 1.0x?
Chandler
Postby Chandler » Wed Oct 04, 2017 8:20 am
Yes drive is selected "0"
TOS 1.02
Arne
Postby Arne » Wed Oct 04, 2017 8:57 am
Then I suggest to measure the DS0 line. There is just an inductor between PSG's DS0 out and the ribbon cable. I have seen defective inductors, but not in signal lines. A multimeter should be fast enough for this purpose.
Have you checked the swapped parts in another ST that they run correctly?
Postby joska » Wed Oct 04, 2017 10:07 am
I guess you have checked the obvious - does the floppy get 5V? And does it get *enough*?
