Mega STe internal jumpers
Fujiyama
Postby Fujiyama » Sun Sep 24, 2017 10:39 pm
Does anyone know the function of the following jumpers inside the Mega STe:
W401
W402
J401 (I haven't been able to find this one in the schematics yet, but it's right next to the floppy drive cable and to the right of the internal ACSI-SCSI host adapter)
I'm asking because I've just received a new 1.44MB Sony MPF-920 floppy drive which I want to try out, but I seem to recall an internal jumper which would allow booting from a "drive 1" instead the more common "Drive 0", so by changing the jumper I could try it out before resoldering the drive 0/1 jumper inside the drive itself. I suspect one of first two jumpers (or a specific combination) will allow that, or are they just for selecting if the boot drive should be an internal or externally attached one?
Are you a good person?
Re: Mega STe internal jumpers
Postby joska » Mon Sep 25, 2017 7:43 am
W401 and W402 routes the disk select signals to the drives. So if you flip those two jumpers the internal drive will become B: and the external A: It's the same on the STE and I believe also the STF and STFM.
It will not help with the "PC floppydrive use ID 1"-problem. For that you will have to modify the drive itself.
I don't know what J401 is for.
Postby czietz » Mon Sep 25, 2017 8:09 am
J401 is the connector for the battery for the RTC. See page 4 in http://dev-docs.exxoshost.co.uk/MegaSTE ... 5-1990.pdf
Fujiyama
Postby Fujiyama » Mon Sep 25, 2017 8:39 am
joska wrote:W401 and W402 routes the disk select signals to the drives. So if you flip those two jumpers the internal drive will become B: and the external A: It's the same on the STE and I believe also the STF and STFM.
Oh, I see.
Yes, a little different from what I was looking for. I'll get out my soldering iron then :wink:
Thanks for clearing this up.
Fujiyama
Postby Fujiyama » Mon Sep 25, 2017 8:41 am
czietz wrote:J401 is the connector for the battery for the RTC. See page 4 in http://dev-docs.exxoshost.co.uk/MegaSTE ... 5-1990.pdf
Aha! No wonder I didn't find it in the schematics as I was looking for jumpers.
I should have known this as I removed the original battery a while back from that very jumper.
Thanks :D
