TOS check Failed at cycle:000001 ?
leech
Postby leech » Fri May 19, 2017 1:37 am
So I got a 1040STe in pretty good shape from ebay, and everything tested out as far as the UltraSatan booting, some games, etc. Yet some games wouldn't launch on this, yet they do off the same UltraSatan/SD Card that works on my TT030.
So I did some crazy upgrades, got a new PSU and the TOS switcher from Chris (exxos), but have the exact same problem. So at this point, I'm thinking some of the capacitors probably need to be replaced, but for the hell of it, I plugged in the diagnostic cartridge, and got this weird error.
Any ideas? I tried Battlechess (worked on TT, not on this system) in both 2.06 and 1.62. I do have the rest of the testing kit, I've just not used it yet (still in it's shrink wrap from Best). Just thought this was weird, and am hoping I didn't screw something up building the adapter.
Any help greatly appreciated!
Re: TOS check Failed at cycle:000001 ?
Postby czietz » Fri May 19, 2017 6:09 am
I think you diagnostic cartridge version is simply to old to know the proper checksum for TOS 2.06 -- that's why it says "new version number". Which version of the diagnostic are you using?
leech
Postby leech » Fri May 19, 2017 5:22 pm
Oh, that's weird. It's one I think I ordered from Arne that has a jumper on it that you set for ST|STE|MSTE|TT|Falcon|SMON.
Postby czietz » Fri May 19, 2017 5:28 pm
This still doesn't answer which version of the cartridge software you're using. This is displayed on the main menu screen.
leech
Postby leech » Fri May 19, 2017 5:43 pm
Derp, my bad. It's version 1.9 from 1991. It even says on the initial screen, TOS 2.06 USA New Version number.
Postby czietz » Fri May 19, 2017 5:56 pm
Version 1.9 of the STE diagnostic is dated May 24, 1991 -- press "$" at the main menu to see this. (Undocumented feature. Bonus: Press "$" and then immediately press "*" for a small easter egg in the diagnostic.)
Considering that TOS 2.06 was only released in November 1991, it's obvious that the correct checksums of the TOS 2.06 ROMs cannot be known to the ver. 1.9 diagnostic.
Postby exxos » Fri May 19, 2017 6:01 pm
If the machine boots to desktop and runs apps, then its unlikely to be a TOS related issue. New PSU, geek points there. I would try testing the RAM viewtopic.php?f=15&t=30110&p=297888#p317371
Also be aware that games have been patched and may work on one machine and not another anyway. Though if you confirm the games work on one STE and not another, then you know it is actually the STE at fault and not the software.
Postby czietz » Fri May 19, 2017 6:07 pm
Doesn't TOS 2.06 do a CRC/checksum test anyway, showing you the "BAD ROM CRC IN CHIP x" warning when something's wrong?
Postby exxos » Fri May 19, 2017 6:08 pm
czietz wrote:Doesn't TOS 2.06 do a CRC/checksum test anyway, showing you the "BAD ROM CRC IN CHIP x" warning when something's wrong?
yep.
leech
Postby leech » Fri May 19, 2017 6:47 pm
Nice! I have not seen that error (thank goodness). I'm betting there are just old capacitors causing my issues. I should try out the loopback stuff, since i have all the cables. At least that confirms I didn't muck up putting your board together for the TOS switcher.
Greenious
Postby Greenious » Fri May 19, 2017 9:18 pm
You get error if you got winx patched TOS aswell. If your ST boots your roms are likely not the problem.
viewtopic.php?t=5040
leech
Postby leech » Fri May 19, 2017 11:45 pm
Hmm, not sure if the rom switcher has a patched TOS or not, exxos can answer that one?
Now I have a ton of switches, I need to figure out a good way to set one up without mangling my case in an absurd way. I wish there had been some way to do it via keyboard combination. But with all the patching going on, most things work on TOS 2.06/3.06 anyhow.
Greenious
Postby Greenious » Fri May 19, 2017 11:57 pm
TOS 1.xx is pointless to patch since you only got it for backwards compatibility. (and winx might screw it up even more)
However, TOS 2.06 and higher I highly recommend WINX. Many improvements and do not cause compatibility issues. By the time TOS 2 came around, programmers had learned to do things the right way. (I have yet to find a program that works with TOS 2.0x worth the disk space that got problems with winx)
leech
Postby leech » Sat May 20, 2017 1:25 am
Well, as a test to see how the diagnostic cartridge works with 1.62, it still gives the failure of cycle 000001, but it is giving me that for the printer and joystick ports. Anyone know if the j10/j11 are supposed to map to mouse/joystick on the ST DMA Test board?
