Atari STF Modulator
TeX38
Atari STF Modulator
Postby TeX38 » Sat Apr 29, 2017 8:49 am
Hi everyone,
I have an Atari 512 STF, and have purchased a modulator for it.
Sadly this fails to work.
to fit the modulator, I had to remove a few components from the modulator area of the motherboard, ie. some diodes, resistors and a transistor.
Do I have to solder any jumpers in that area or other areas for the modulator to work?
The motherboard version is C070523-001 Rev D.
Also, I would like to upgrade the ram, there are empty pads ready to take the new chips, but do I have to set any jumpers for this to work?
I also have a non working 1040STFM version C103414-001 Rev 1.1. motherboard.
I have found all the clock freqs to be correct but there is absolutely no data bus or address bus activity.
Any ideas?
Terry.
Arne
Re: Atari STF Modulator
Postby Arne » Sat Apr 29, 2017 10:57 am
Grab the Service Manual, read the chapter "Troubleshooting a dead unit" and then check /HALT, /RESET and /BERR.
TeX38
Postby TeX38 » Sun Apr 30, 2017 12:53 am
Thanks Arne,
I got the manual, and HALT is being held LOW, there may be a fault with the 556, and/or the ls05, I removed the 74LS05 and HALT is still being held LOW.
Faulty CPU maybe?
RESET and BERR are both high.
Arne
Postby Arne » Sun Apr 30, 2017 4:33 am
/HALT is bidirectional.
TeX38
Postby TeX38 » Sun Apr 30, 2017 9:59 am
Yer, makes it more difficult to trouble shoot.Wish I had a diagnostic cartridge. be very handy.
