Problem with vertical Lines on a 520 STFM
ely
Postby ely » Thu Jul 24, 2014 8:51 pm
I took my 520 STFM (TOS 1.2) out of the garage today (it hasn't been switched on in close to 10 years) and it appears to work okay but for vertical lines across the screen (see photo below) regardless of whether in Low or Medium resolution. It still seems to play demos and boot to TOS etc. etc. and for a brief time they disappeared but then came back :?
Anyone seen this before and know a cure?
Arne
Re: Problem with vertical Lines on a 520 STFM
Postby Arne » Fri Jul 25, 2014 4:59 am
Check your ST's memory.
mc6809e
Postby mc6809e » Fri Jul 25, 2014 5:03 am
Open it up and re-seat any socketed chips.
They can creep out of their sockets over time as the ambient temperature cycles.
paul92706
Postby paul92706 » Fri Jul 25, 2014 5:40 am
I would for sure do what Arne/Mc6809e say, also check PSU and video cables. :mrgreen:
ely
Postby ely » Fri Jul 25, 2014 7:20 am
Thanks for the replies, the mahcine does have an extra 512KB ram upgrade that was always a bit flakey so I'll remove that and see if it solves it. A couple of friends have suggested it could be a PSU +5 volt issue to the Shifter chip. So I'll check that also.
rockardbiker
Postby rockardbiker » Wed Nov 22, 2017 10:00 pm
Hi Ely, Did you ever fix this issue as I have the same on my 520STFM
Tel
