N.AES and video resolution
All about the serious stuff.
Saturnin51
Postby Saturnin51 » Sun Dec 24, 2017 11:11 am
I have installed N.AES 1.0 with MinT 1.18 on my Falcon 16 Mo. Just a problem: I can't modify the video resolution. N.AES starts in low resolution and the desktop (Thing or Teradesk) are also in low resolution. With Teradesk I can modify it but nothing occurs.
There is no video parameter into NAES.CNF and in the MINT.CNF video=27.
An idea ?
Falcon 030-14 Mo - FDI Steinberg -Soundpool Analog 8 - SMP24 - Cubase Audio Falcon 2.06 dongle - SC55 - SG64 - Yamaha CBX-T3
Re: N.AES and video resolution
Postby joska » Sun Dec 24, 2017 11:34 am
Use N_CHRES.PRG that's shipped with N.AES (see in the APPS subfolder).
Saturnin51 wrote:and in the MINT.CNF video=27.
MiNT does not know or care about video resolution. If you add a "video = " line in mint.cnf it will simply be ignored as this command/setting is not recognized by MiNT. You are thinking about the "video" setting in XaAES and MyAES :)
Btw is there any particular reason for using N.AES 1.0? That version is quite buggy. You should use 2.0, or atleast 1.1
Saturnin51
Postby Saturnin51 » Sun Dec 24, 2017 2:02 pm
OK I install the 1.10 update. But N.AES starts always in low resolution. I have to change it by CTRL-ALT-R. Is there a way to run directly in the right resolution ?
Return to “Applications”
