Unknown extension (for me..)
All about the serious stuff.
nagual
Postby nagual » Fri Dec 15, 2017 12:47 am
Does anyone know what kind of extension is GRB ?
I found it on Atari Cd Library - CD 09 - a folder full with files with extension GRB.
According some cryptic info, files with GRB extension is full version of software, but I didn't understand is there any key to unlock this software, or just some program which "unlocked" files...
Cheers! :cheers:
Re: Unknown extension (for me..)
Postby rockyone » Tue Feb 13, 2018 2:56 pm
or find this CD ?
nagual
Postby nagual » Tue Feb 13, 2018 8:02 pm
As i said , there's a lot of software, collecting from (I think) various sources, and then locked/compressed/other with some unknown program (for me, of course!)
And I have this CD, but still don't understand how to unlock or whatever this software:-)
spiny
Disk Imager Supreme
Disk Imager Supreme
Postby spiny » Tue Feb 13, 2018 8:12 pm
can you zip the files and attach them in this thread ?
nagual
Postby nagual » Tue Feb 13, 2018 10:33 pm
Here it is:-)
Postby czietz » Wed Feb 14, 2018 11:46 am
If you posted more than one GRB file, one could look for patterns and whether this is possibly a very simple encryption that can be broken without knowledge of the algorithm or the key.
nagual
Postby nagual » Wed Feb 14, 2018 2:57 pm
Ok, here's the 4 files of 25 with same extensions:-)
If you need all of them, I will put it on my Google drive:-)
Cheers! :cheers:
Postby czietz » Wed Feb 14, 2018 6:08 pm
After performing some cryptoanalysis on the files, I was able to deduce the encryption algorithm that was used. Fortunately, this algorithm is prone to an attack that allows the recovery of the decrypted data without knowledge of the key. Find attached a decrypted file as proof. I think it's OK to post this here, since in the meantime Boxkite has been released as freeware.
Which applications other than those you posted are on your CD, BTW? Maybe something that was lost until now? Then I could recover it by decrypting the file...
nagual
Postby nagual » Wed Feb 14, 2018 10:44 pm
Thank you for your work:-)
Here's the list of programs, seems like older versions , but, all are or freeware or abandoned, so I can't see any problem to post it here:-)
Cheers! :cheers:
Postby czietz » Thu Feb 15, 2018 7:29 am
A lot of the programs -- I didn't check all of them -- also were on the Whiteline CDs Alpha to Kappa, unencrypted: http://deltalabs.biz/atari-whiteline-cd-alpha.htm
nagual
Postby nagual » Thu Feb 15, 2018 12:25 pm
Yes, you're right..I must be blind, I checked some of apps, hope there's a same version as encrypted one:-)
Once again, thank you for your effort and time:-)
Postby czietz » Thu Feb 15, 2018 5:35 pm
No worries. It was a fun little project to analyze and decrypt the files.
penguin
Postby penguin » Thu Feb 15, 2018 7:26 pm
nagual wrote:Thank you for your work:-)
They all sound familiar. Just search for them in the UTD and you'll see a list of public domain disks and CDs which include these programs. PIAG should be Play It Again GEM, officially declared freeware by the author: http://www.dirk-hagedorn.de/?page_id=13
AtariUpToDate - Atari ST/TT/Falcon software database and version tracker: http://www.atariuptodate.de
st-computer magazine - http://st-computer.atariuptodate.de/
nagual
Postby nagual » Fri Feb 16, 2018 11:32 am
Thank you:-)
Return to “Applications”
