accelerating NVDI startup ?
All about the serious stuff.
Moulinaie
Postby Moulinaie » Fri Nov 10, 2017 2:26 pm
I have installed NVDI 5.03 on my TT.
At each boot, it reloads and updates the font list, this takes some seconds, but I never change my font settings!
Is there a way to bypass this and keep the previous settings ?
Guillaume;
ama
Re: accelerating NVDI startup ?
Postby ama » Fri Nov 10, 2017 3:05 pm
Maybe helps the NVDI - CPX "Fonts & Caches"
Postby wongck » Fri Nov 10, 2017 3:05 pm
untick the check tickbox in the Fonts control panel ?
Moulinaie
Postby Moulinaie » Fri Nov 10, 2017 3:44 pm
wongck wrote:untick the check tickbox in the Fonts control panel ?
Thanks, I didn't notice this CPX before...
I tried this, but nothing changes, some seconds are taken to "load" and update de font list.
Guillaume.
Moulinaie
Re: accelerating NVDI startup ? (solved)
Postby Moulinaie » Fri Nov 10, 2017 3:53 pm
My FIFPATH was not defined in the NVDI.INF file...
So it was buildind the table at each boot instead of reading the FIF file.
Guillaume.
Postby wongck » Sat Nov 11, 2017 1:05 am
Glad you found the issue.
Moulinaie wrote:My FIFPATH was not defined in the NVDI.INF file...
Did you not install using the installer ?
Moulinaie
Postby Moulinaie » Sun Nov 12, 2017 9:20 am
wongck wrote:Glad you found the issue.
I did, but then I manually changed some folders...
So the INF file was not up to date!
Guillaume.
Return to “Applications”
