Atari on home network
All about the serious stuff.
Moulinaie
Postby Moulinaie » Wed Nov 01, 2017 4:54 pm
I have both my PC and Atari plugged in my ADSL box in Ethernet.
Is it possible for the PC (Win10) to "see" the Atari and get a copy of all its hard disk? (I want to backup my TT)
Or should I install a FTP server on the PC and use a FTP client on the Atari ?
Guillaume.
frank.lukas
Re: Atari on home network
Postby frank.lukas » Wed Nov 01, 2017 5:13 pm
As an example I use a NFS Server under Apple OSX/macOS and the build in NFS Client from MiNT on my Atari TT ...
Moulinaie
Postby Moulinaie » Wed Nov 01, 2017 5:27 pm
frank.lukas wrote:As an example I use a NFS Server under Apple OSX/macOS and the build in NFS Client from MiNT on my Atari TT ...
Interesting !
Is there some informations somewhere to setup the NFS client under Mint?
Guillaume.
frank.lukas
Postby frank.lukas » Wed Nov 01, 2017 5:30 pm
Faucon2001
Postby Faucon2001 » Wed Nov 01, 2017 5:36 pm
You have several options.
- Setup a SAMBA or NFS server on your TT (use sparemint packages) and share your drives
- set your PC as NFS server, and install mint NFS client on your TT (samba client works in read only with recent servers). Should work also with Magic if you use MagicNet
- setup your TT as ftp server with vasilli ftp server ( not sure of the name)
-set your PC as FTP server and use the excellent litchi client on your TT
I personally use the 2d and 4th solution.
Philippe
Neurotoxic
Postby Neurotoxic » Wed Nov 01, 2017 6:42 pm
The easiest way for data transfer in such a network is to use ftp. You may use Litchi as a client on the Atari side or FTP Server as a server.
http://ptonthat.fr/litchi/
http://users.otenet.gr/~papval/
All other solutions are a little bit more complicated. You have to modify a lot of configuration files on both sides and you often have to try a lot until it works.
520 ST(M) (TOS 1.02), Falcon030 (16 MHz, 16 MB RAM, CF-Card, MiNT & MyAES), Milan040 (25 MHz, 48 MB RAM, EasyMiNT 1.90), Firebee, PowerMac G5 Late 2005 (2 x 2,3 GHz, Mac OS 10.5), iMac 4K Late 2015 (intel Core i7 4 x 3,3 GHz, Mac OS 10.11.6), IBM XT SFD (640 KB RAM, DR DOS 6.0), Compaq LTE 5300 (Pentium/133 MHz, DR-DOS 7.03), AT-PC (Cyrix 6x86L/200 MHz, Windows 98 SE/MS-DOS 6.22 & Windows 3.11)
dbsys
Postby dbsys » Wed Nov 01, 2017 8:40 pm
Postby wongck » Wed Nov 01, 2017 10:58 pm
You can mount your Windows shared folders via sharitylight directly on your Atari just like it is one of your drive.
It's similar to using NET USE on a DOS machine to access the drive.
https://sites.google.com/site/probehous ... aritylight
This was on Win 7 and not tried on Win 10. IIRC MS once lobotomised it's SMB so that all these and other SMB client failed. Created an uproar and MS have to patch their SMB to make it work again. So i am not sure if something similar done on Win 10 (done in the name of security).
Postby mikro » Wed Nov 01, 2017 11:37 pm
Depending on the size of your hard disk, ftp can take forever. The easiest option is to either connect your disk directly to PC or make an image of it and mount it in Aranym or similar.
Neurotoxic
Postby Neurotoxic » Thu Nov 02, 2017 7:35 am
wongck wrote:You can mount your Windows shared folders via sharitylight directly on your Atari just like it is one of your drive.
This tool didn't work for me. I tried it using esayMiNT 1.90 with MiNT 1.19.cur from November 22nd, 2015 on my Milan040. I tried to mount a smb folder that was shared by my Powermac G5 using Mac OS 10.5.8. Perhaps I'm a little bit to stupid for this stuff. Editing configuration files isn't that easy if you aren't familiar with all the unix stuff and the syntax. But I've got NFS running as a client and server on the Atari and on the Mac OS 10.5.8 side. That did take a lot of time until I got it running. So I tried Sharity-Light but it didn't work after spending time of an hour so I decided not to use it because NFS was already running. For guys like me there must be an installer that does all the file editing in the background and a nice configuration program using gem. 8O
Postby joska » Thu Nov 02, 2017 8:17 am
Yes, good advice. This is the easiest (and probably fastest) way to transfer files as long as you have a supported network card. SMB and NFS requires a lot more from the user, and is totally overkill for the suggested use (backup).
Neurotoxic wrote:For guys like me there must be an installer that does all the file editing in the background and a nice configuration program using gem.
Remember, the "Easy" in EasyMiNT doesn't mean easy to use, but easy to install. You still end up with a very complex setup that has to be configured manually.
Easy filesharing is one of my goals in VanillaMiNT, but there is nothing "easy" about filesharing on the Atari so this requires a lot of work :)
Moulinaie
Postby Moulinaie » Thu Nov 02, 2017 8:41 am
dbsys wrote:Use the uip tool:
viewtopic.php?f=14&t=27365
It runs on the TT and I get the IP address.
Then on the PC I can see the files, but no easy way to download a whole disk. (It looks like it only works file by file and not at the folder level !)
Guillaume.
Postby joska » Thu Nov 02, 2017 8:46 am
Which browser so you use? Looks like you need Chrome to up/download folders.
Postby simonsunnyboy » Thu Nov 02, 2017 9:12 am
uip would be my suggestion aswell. I had better results using Firefox with its GUI though.
I already suggested to add a crawler providing URLs so one could download from the Atari through a crawler tool like wget.
Moulinaie
Postby Moulinaie » Thu Nov 02, 2017 9:14 am
joska wrote:Which browser so you use? Looks like you need Chrome to up/download folders.
I have just installed Chrome and nothing happens... I can't drag and drop from the TT to the PC.
Guillaume.
Moulinaie
Postby Moulinaie » Thu Nov 02, 2017 9:16 am
Guillaume.
It can drag and drop from PC to the TT....
But I wanted to backup my TT, not my PC..!!
Guillaume.
Postby wongck » Thu Nov 02, 2017 11:46 am
Like I said, Sharitylight is very picky on SMB and slight changes in the protocol will make it not work. I am not sure how compatible is the Mac OS SMB with this tool. MS had to patch it's SMB to make it work. If MacOS is not compatible than Apple will have to patch it to do the jobs.
Edit: to clarify the tool here, I added Sharitylight
Postby joska » Thu Nov 02, 2017 11:48 am
AFAICS it does not use SMB but HTTP.
Postby wongck » Thu Nov 02, 2017 11:59 am
One can always try the CURL command lines to see if it is working.
Moulinaie
Postby Moulinaie » Thu Nov 02, 2017 12:28 pm
Finally....
The FTP reqires some changes that I don't understand (I'm bad at networking).
So I came back to my old ZIP 100 : copying with two disks is not so long.
I saved the two TT's this morning.
Guillaume.
Return to “Applications”
