VanillaMint Trouble
All about the serious stuff.
ccarl84
VanillaMint Trouble
Postby ccarl84 » Wed Sep 27, 2017 8:07 pm
I want to try VanillaMint on my TT (4,16 Mo)
I have this message after the 1st boot :
"system resource : 1DA6004 (u:\c\MINT\1-19-CUR\XAES\xaaes016.rsc)
exeption 10 for AESSTS pc:115F7CE addr:69DC01E4
pid 0 (MiNT) : Operating system killed
FATAL ERROR. You must reboot the system."
If you have an idea ?
Thank you.
ccarl84
Re: VanillaMint Trouble
Postby joska » Wed Sep 27, 2017 8:23 pm
First question - did you follow the installation instructions exactly?
ccarl84
Postby ccarl84 » Wed Sep 27, 2017 8:48 pm
Yes (I hope :-)),
I have only nvdi.prg and wdialog.prg on start (and his .acc).
My mint is so MINT030.prg
that's all.
Postby joska » Wed Sep 27, 2017 8:56 pm
ccarl84 wrote:wdialog.prg on start (and his .acc).
So you did not follow the instructions exactly :)
1. Disable *everything* in the auto-folder except nvdi.prg.
2. Disable *all accs*.
3. Copy VanillaMiNT to the root of drive C.
4. Make sure that NVDI.PRG starts before MINT030.PRG.
Now reboot. Unless the downloaded archives are damaged (or you have a non-working NVDI installation) VanillaMiNT will now work. You can now start putting things back as needed.
ccarl84
Postby ccarl84 » Wed Sep 27, 2017 9:01 pm
Well I will try.
Tx joska :-)
ccarl84
Postby ccarl84 » Wed Sep 27, 2017 9:15 pm
I have tried, so :
- AUTO : only NVDI.prg and MINT30.prg.
- Folder CPX rename CPS to take no CPX
same result :x
Tomorow it's a another day :wink:
Bye
Postby joska » Wed Sep 27, 2017 9:42 pm
Does NVDI work when you boot without MiNT? And you have checked that NVDI is started before MiNT in the auto-folder? And *all* accessories except COPS.ACC is disabled?
ccarl84
Postby ccarl84 » Thu Sep 28, 2017 4:50 pm
joska wrote:Does NVDI work when you boot without MiNT? And you have checked that NVDI is started before MiNT in the auto-folder? And *all* accessories except COPS.ACC is disabled?
Well,
NVDI start with or without MiNT : done.
At start : NVDI start and After I have mint boot ... and crash.
only COPS.ACC is eanable
:shrug:
Postby joska » Thu Sep 28, 2017 7:35 pm
Then I have no other suggestions than that you download and install VanillaMiNT again.
ccarl84
Postby ccarl84 » Thu Sep 28, 2017 7:46 pm
joska wrote:Then I have no other suggestions than that you download and install VanillaMiNT again.
ok, tx for your interest.
I will download again and I Format all and try.
very,very tx,
To be continued ....
Postby mikro » Thu Sep 28, 2017 9:08 pm
ccarl84 wrote:"system resource : 1DA6004 (u:\c\MINT\1-19-CUR\XAES\xaaes016.rsc)
Actually this looks like your file may be corrupted.
Return to “Applications”
