Problem to make a 256col icon with RSM or Intrface...
All about the serious stuff.
Playmobil
Postby Playmobil » Tue Sep 12, 2017 5:14 pm
Hi guys, I'll try to explain with my low-level english...
I need to make somes 256col icons.. I have GIF icons and convert them in X-IMG using Smurf or Gemview (I have tested both, but the issue is the same)
After that I have à nice 256col icon in format .IMG...
If I open this .IMG with RSM (RessourceMaster), then I'm loosing à lot of colours and gradient effect... The icon inside RSM is in 8bits, see below...
If I open this .IMG with Interface 2.33, all seem OK, good colors, but I'm not enable to put it inside the editor, it's stay blank...
Looks this screenshots :
With RSM, bad colors, no gradient effect, at the top-left it's the .IMG open with ZVIEW and below it's the same in RSM :
With INTERFACE, the .IMG is very good, but unable to edit it !
I'm using Aranym+Tos404+Xaaes+fvdi+nvdi, same issue with MyAES or Emutos...
Maybe it's exist another way to do that.... Another Icon Editor, but all my search are null...
Thanks in advance
Re: Problem to make a 256col icon with RSM or Intrface...
Postby mikro » Tue Sep 12, 2017 9:36 pm
What about other (existing) 256-colour icons / RSC files? Can you edit them?
Playmobil
Postby Playmobil » Tue Sep 12, 2017 10:03 pm
mikro wrote:What about other (existing) 256-colour icons / RSC files? Can you edit them?
Yes, it"s working with an existing RSC, the problem with Interface is the Copy/Paste from .IMG to the editor... This function work under Aranym+plain TOS404 256col... It's seem that Interface don't like FVDI or NVDI...
Another problem with Interface, when I open a RSC with 256 color icons, somes colors are not good (maybe 5 or 6 - palette a litle bit different)
On the left RSM, right Interface :
Return to “Applications”
