Sprite Editor
All about the serious stuff.
Arne
Sprite Editor
Postby Arne » Tue Apr 25, 2017 9:45 am
I'm looking for a Sprite Editor supporting Falcon's 256 colour mode. Supporting 16x16 pixel, better 32x32 pixel. Is it available somewhere?
Tatu
Re: Sprite Editor
Postby Tatu » Tue Jul 25, 2017 6:01 pm
You could try programming one yourself with GFA Basic 3.6TT perhaps? On my falc, 256-colour mode doesn't work in the standard editor, but will work when compiled and run from the desktop. Also with gfa basic you need to remember the maximum string variable size is 32 kb(same as ST screen), as it stores bitmaps in strings. http://paradize.final-memory.org/gfabasic.shtml I have used some of these example codes.
chlu600
Re: Sprite Editor
Postby chlu600 » Tue Jul 25, 2017 6:32 pm
I have been using Apex Media for such tasks. Even if it were 20+ years ago...
http://dhs.nu/files.php?t=single&ID=142
lp
Re: Sprite Editor
Postby lp » Tue Jul 25, 2017 7:10 pm
Tatu wrote:You could try programming one yourself with GFA Basic 3.6TT perhaps? On my falc, 256-colour mode doesn't work in the standard editor, but will work when compiled and run from the desktop. Also with gfa basic you need to remember the maximum string variable size is 32 kb(same as ST screen), as it stores bitmaps in strings. http://paradize.final-memory.org/gfabasic.shtml I have used some of these example codes.
GFA 3.6 editor can run in 256 color modes with this:
http://www.run-software.de/bastard.php
Tatu
Re: Sprite Editor
Postby Tatu » Tue Jul 25, 2017 11:08 pm
Bastard 4.0 doesn't start on my falc, and it crashes the computer after screen mode change.
lp
Re: Sprite Editor
Postby lp » Wed Jul 26, 2017 12:59 am
I use it on my Hades for many years at 1280x1024 in 256 colors. I currently use it on aranym 1600x1024 in 256 colors. I don't know what you mean by "after screen mode change". I am already in 256 color mode when I start, no mode changes here.
Tatu
Re: Sprite Editor
Postby Tatu » Wed Jul 26, 2017 8:21 am
After I tried starting it from 256-color low res, the falcon crashes when switching back to st-low. I have TOS 4.04, 14 Megs, Putnik's HD Driver, CF card. Tried on a "minimal" hd partition with no accs or auto programs.
Re: Sprite Editor
Postby AtariZoll » Wed Jul 26, 2017 10:53 am
I would propose heretic solution: doing it on PC, with some better Paint program, or if such exists, dedicated sprite editor.
Saving as 256 color, palette based BMP format - what is easy to convert to Falcon display format. I use Paint Shop Pro 9 (last Adobe free version).
lp
Re: Sprite Editor
Postby lp » Wed Jul 26, 2017 11:33 am
I tried it on Hatari as I don't have a Falcon anymore and it seems to work if I set video mode: 256 colors, 80 columns, interlace On or double line Off
Config file I used:
SetProjectPath :=0
LoadFileAndRun :=0
Bell :=0
Scrambler :=1
HardwareBlit :=1
NoClock :=0
FreMemory :=0
MinMemory :=0
SetAesName :=GFABASIC
GfaBasicPath :=C:\CODE\GFA\GFABASIC.PRG
SetDefaultPath :=C:\
Fileselector :=
You will need to adjust "GfaBasicPath" of course.
Then start bastard.prg.
Return to “Applications”
