VanillaMiNT has finally been updated
All about the serious stuff.
Postby joska » Fri Mar 24, 2017 9:32 pm
A new version of VanillaMiNT is finally available at http://vanillamint.atari.org.
New in this version:
- Support for Hades, CT60, Afterburner and Amiga (!).
- Updated configuration tools. Video mode selector added.
- Latest Teradesk.
This is an interim release. Milan and 68000 releases are in the pipeline, but I need to tweak and test these more. Especially the 68000 version needs attention. I'm releasing this version now so people can try MiNT on their newly aquired CT60e :)
Trixster
Re: VanillaMiNT has finally been updated
Postby Trixster » Fri Mar 24, 2017 10:19 pm
Nice one!
Atari Falcon + CT60e | Atari 2600 | Atari Jaguar | A1200 + 80mhz B1260 + Indi AGA2 + Ide-fix Express | SNES
A4000/060 CS Mk2 + Indi AGA + Voodoo3 + G3 900Mhz PPC + Deneb | A3000/060 WarpEngine + CV64 + Deneb + 486SLC2 | PS1
Acorn A3020 | A3000 | A420/1 | BBC B | Atom | Master Turbo | A500 | C64 | 3DO | Saturn | PS2 | CPC6128
rian_ata
Postby rian_ata » Fri Mar 24, 2017 11:02 pm
Thanks so much Joska! Great achievement and will install on my CT63e :-)
Postby wongck » Sat Mar 25, 2017 12:25 am
Great job !!
Thanks for spreading Mint, I hope more people will now use it.
TheNameOfTheGame
Postby TheNameOfTheGame » Sat Mar 25, 2017 12:37 am
Thanks! I'm going to try this on my Hades060.
fmh
Postby fmh » Sat Mar 25, 2017 2:13 am
I will try it under Aranym and then the FireBee when it becomes available.
Atari Gamer
FireBee
vido
Postby vido » Sat Mar 25, 2017 7:30 am
fmh wrote:I will try it under Aranym and then the FireBee when it becomes available.
You dont need VanillaMiNT for the FireBee. MiNT is allready preinstalled on it.
trecool
Postby trecool » Sat Mar 25, 2017 7:40 am
I get k_init: failed on ct60e
marss
Postby marss » Sat Mar 25, 2017 7:46 am
big thanks
Postby joska » Sat Mar 25, 2017 8:29 am
trecool wrote:I get k_init: failed on ct60e
Can you give me an exact listing of your autofolder (unsorted!) and also mint.ini, mint.cnf and xaaes.cnf? Also, you *did* download the 060 archive? And booting in 060 mode?
trecool
Postby trecool » Sat Mar 25, 2017 9:05 am
I have a newly formatted cf card using hdd9.1 driver.
I installed ndvi and then just transferred the VanillaMint files.
I did download the 060 archive.
I haven't changed any cnf/ini file.
No sort: NVDI/WDIALOG/MINT
I don't see any video.cnf file under /mint/
Postby joska » Sat Mar 25, 2017 9:05 am
Start by getting rid of wdialog.
trecool
Postby trecool » Sat Mar 25, 2017 9:13 am
Already did nothing changed...
Postby joska » Sat Mar 25, 2017 9:44 am
Then delete it and wait for me to get my own CT60e running so I can test this myself :) But it's sure to be a configuration error (either inside or outside of VanillaMiNT), because this kernel has been confirmed to run correctly on the CT60e.
Postby joska » Sat Mar 25, 2017 9:47 am
trecool wrote:I don't see any video.cnf file under /mint/
There won't be one until you've created it with the screenmode selector. But it does not matter, XaAES will use the default video mode when this file is missing.
Maybe you can try to enable the bootlog in MiNT's boot menu and post it here?
frost
Postby frost » Sat Mar 25, 2017 10:36 am
Thanks Joska !
My blog, mostly about Atari and demo stuff.
trecool
Postby trecool » Sat Mar 25, 2017 5:51 pm
Ok, I get the following
after that, system unmounts everything and reboots...
Here is my boot.log file (sorry for being images)
Trixster
Postby Trixster » Sat Mar 25, 2017 9:30 pm
Have you extracted all 6 zip files?
trecool
Postby trecool » Sat Mar 25, 2017 9:45 pm
Yep. That was the first thing that came to my mind.
Hope STZip didnt make a mess there, but I dont think so.
rian_ata
Postby rian_ata » Sat Mar 25, 2017 9:53 pm
060 version works perfectly fine for me on CT63e, with HDDriver 8.18 and NVDI5.01.
Trixster
Postby Trixster » Sat Mar 25, 2017 9:57 pm
rian_ata wrote:060 version works perfectly fine for me on CT63e, with HDDriver 8.18 and NVDI5.01.
Yeah, works ok for me too.
Postby joska » Sat Mar 25, 2017 10:39 pm
trecool wrote:Hope STZip didnt make a mess there, but I dont think so.
I think you have the explanation there. ST-Zip is... old. I've had problems extracting "new" zips with ST-Zip before so I stopped using it. Use a more recent zip/unzip, or unzip on your PC before transfering the files.
For reference, here's the filelist from the 1-19-cur folder in VanillaMiNT 060. Does the names and filesizes matches what you got on your Falcon?
total 256
-rw-rw-r-- 1 joska joska  2452 mars  24 16:45 COPYING
-rw-rw-r-- 1 joska joska 17992 mars  24 16:45 COPYING.GPL
-rw-rw-r-- 1 joska joska 26532 mars  24 16:45 COPYING.LGPL
-rw-rw-r-- 1 joska joska  2543 mars  24 16:45 COPYING.MiNT
-rwxrwxr-x 1 joska joska 46892 mars  24 16:45 ext2.xfs
-rwxrwxr-x 1 joska joska 83424 mars  24 16:45 inet4.xdd
-rwxrwxr-x 1 joska joska 14329 mars  24 16:45 mfp.xdd
-rwxr-xr-x 1 joska joska  7974 mars  24 16:45 mint.cnf
-rwxr-xr-x 1 joska joska   172 mars  24 16:45 mint.ini
-rw-rw-r-- 1 joska joska 13264 mars  24 16:45 sample.cnf
-rwxrwxr-x 1 joska joska 14991 mars  24 16:45 scc.xdd
drwxrwxr-x 7 joska joska  4096 mars  24 16:45 xaaes
-rwxrwxr-x 1 joska joska  1421 mars  24 16:45 xconout2.xdd
./xaaes:
total 856
-rw-rw-r-- 1 joska joska  35149 mars  24 16:45 example.cnf
drwxrwxr-x 2 joska joska   4096 mars  24 16:45 gradient
drwxrwxr-x 4 joska joska   4096 mars  24 16:45 _img
-rwxrwxr-x 1 joska joska  35240 mars  24 16:45 moose.adi
-rwxrwxr-x 1 joska joska  35249 mars  24 16:45 moose_w.adi
drwxrwxr-x 2 joska joska   4096 mars  24 16:45 pal
drwxrwxr-x 2 joska joska   4096 mars  24 16:45 widgets
-rw-rw-r-- 1 joska joska  72122 mars  24 16:45 xaaes016.rsc
-rw-rw-r-- 1 joska joska  35190 mars  24 16:45 xaaes016.rsl
-rwxrwxr-x 1 joska joska 527003 mars  24 16:45 xaaes060.km
-rwxr-xr-x 1 joska joska  27032 mars  24 16:45 xaaes.cnf
-rw-rw-r-- 1 joska joska   7998 mars  24 16:45 xaaeswdg.rsc
-rw-rw-r-- 1 joska joska   2582 mars  24 16:45 xa_help.cs
-rw-rw-r-- 1 joska joska   6128 mars  24 16:45 xa_help.de
-rw-rw-r-- 1 joska joska   4657 mars  24 16:45 xa_help.es
-rw-rw-r-- 1 joska joska   5990 mars  24 16:45 xa_help.fr
-rw-rw-r-- 1 joska joska   3805 mars  24 16:45 xa_help.hu
-rw-rw-r-- 1 joska joska   5011 mars  24 16:45 xa_help.it
-rw-rw-r-- 1 joska joska   4760 mars  24 16:45 xa_help.ru
-rw-rw-r-- 1 joska joska   5014 mars  24 16:45 xa_help.txt
-rwxrwxr-x 1 joska joska   5171 mars  24 16:45 xaloader.prg
-rw-rw-r-- 1 joska joska   3464 mars  24 16:45 xa_xtobj.rsc
drwxrwxr-x 2 joska joska   4096 mars  24 16:45 xobj
./xaaes/gradient:
total 176
-rw-rw-r-- 1 joska joska 8247 mars  24 16:45 autumn.c
-rw-rw-r-- 1 joska joska 8462 mars  24 16:45 default.c
-rw-rw-r-- 1 joska joska 8254 mars  24 16:45 flwrpwr.c
-rw-rw-r-- 1 joska joska 8228 mars  24 16:45 g_blue.c
-rw-rw-r-- 1 joska joska 8036 mars  24 16:45 g_cyan.c
-rw-rw-r-- 1 joska joska 8034 mars  24 16:45 g_green.c
-rw-rw-r-- 1 joska joska 8059 mars  24 16:45 g_purple.c
-rw-rw-r-- 1 joska joska 8054 mars  24 16:45 g_red.c
-rw-rw-r-- 1 joska joska 8130 mars  24 16:45 g_yellow.c
-rw-rw-r-- 1 joska joska  441 mars  24 16:45 Makefile
-rw-rw-r-- 1 joska joska 8265 mars  24 16:45 menubar.c
-rw-rw-r-- 1 joska joska 9180 mars  24 16:45 mint.c
-rw-rw-r-- 1 joska joska 8263 mars  24 16:45 n_blue.c
-rw-rw-r-- 1 joska joska 8071 mars  24 16:45 n_cyan.c
-rw-rw-r-- 1 joska joska 8039 mars  24 16:45 n_deflt.c
-rw-rw-r-- 1 joska joska 8069 mars  24 16:45 n_green.c
-rw-rw-r-- 1 joska joska 8094 mars  24 16:45 n_purple.c
-rw-rw-r-- 1 joska joska 8089 mars  24 16:45 n_red.c
-rw-rw-r-- 1 joska joska 8047 mars  24 16:45 n_yellow.c
./xaaes/_img:
total 8
drwxrwxr-x 2 joska joska 4096 mars  24 16:45 8b
drwxrwxr-x 2 joska joska 4096 mars  24 16:45 hc
./xaaes/_img/8b:
total 200
-rw-rw-r-- 1 joska joska 30052 mars  24 16:45 dbox.img
-rw-rw-r-- 1 joska joska 18173 mars  24 16:45 dbutton.img
-rw-rw-r-- 1 joska joska 30052 mars  24 16:45 dtext.img
-rw-rw-r-- 1 joska joska  8166 mars  24 16:45 exterior.img
-rw-rw-r-- 1 joska joska 15147 mars  24 16:45 info.img
-rw-rw-r-- 1 joska joska 30784 mars  24 16:45 popbkg.img
-rw-rw-r-- 1 joska joska 19121 mars  24 16:45 slide.img
-rw-rw-r-- 1 joska joska 11835 mars  24 16:45 slider.img
-rw-rw-r-- 1 joska joska  6092 mars  24 16:45 slwtitle.img
-rw-rw-r-- 1 joska joska 18173 mars  24 16:45 wtitle.img
./xaaes/_img/hc:
total 168
-rw-rw-r-- 1 joska joska 15193 mars  24 16:45 dbox.img
-rw-rw-r-- 1 joska joska 47747 mars  24 16:45 dbutton.img
-rw-rw-r-- 1 joska joska 15193 mars  24 16:45 dtext.img
-rw-rw-r-- 1 joska joska  9245 mars  24 16:45 exterior.img
-rw-rw-r-- 1 joska joska  8920 mars  24 16:45 info.img
-rw-rw-r-- 1 joska joska 24352 mars  24 16:45 popbkg.img
-rw-rw-r-- 1 joska joska 15634 mars  24 16:45 slide.img
-rw-rw-r-- 1 joska joska  9245 mars  24 16:45 wtitle.img
./xaaes/pal:
total 8
-rw-rw-r-- 1 joska joska 1540 mars  24 16:45 gem.pal
-rw-rw-r-- 1 joska joska 1540 mars  24 16:45 nvdi.pal
./xaaes/widgets:
total 364
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 adam.hrd
-rw-rw-r-- 1 joska joska  8506 mars  24 16:45 adam.rsc
-rw-rw-r-- 1 joska joska   756 mars  24 16:45 baroqwdg.h
-rw-rw-r-- 1 joska joska   208 mars  24 16:45 baroqwdg.hrd
-rw-rw-r-- 1 joska joska  8508 mars  24 16:45 baroqwdg.rsc
-rw-rw-r-- 1 joska joska   156 mars  24 16:45 cbox1214.h
-rw-rw-r-- 1 joska joska    44 mars  24 16:45 cbox1214.hrd
-rw-rw-r-- 1 joska joska   354 mars  24 16:45 cbox1214.rsc
-rw-rw-r-- 1 joska joska   155 mars  24 16:45 cboxwdg.h
-rw-rw-r-- 1 joska joska    44 mars  24 16:45 cboxwdg.hrd
-rw-rw-r-- 1 joska joska   348 mars  24 16:45 cboxwdg.rsc
-rw-rw-r-- 1 joska joska   156 mars  24 16:45 cboxwidg.h
-rw-rw-r-- 1 joska joska    44 mars  24 16:45 cboxwidg.hrd
-rw-rw-r-- 1 joska joska   342 mars  24 16:45 cboxwidg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 gemjwdg.hrd
-rw-rw-r-- 1 joska joska  8514 mars  24 16:45 gemjwdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 gilwidg.hrd
-rw-rw-r-- 1 joska joska  8506 mars  24 16:45 gilwidg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 homwdg.hrd
-rw-rw-r-- 1 joska joska 11434 mars  24 16:45 homwdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 ligt_wdg.hrd
-rw-rw-r-- 1 joska joska 13890 mars  24 16:45 ligt_wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 magicwdg.hrd
-rw-rw-r-- 1 joska joska  8346 mars  24 16:45 magicwdg.rsc
-rw-rw-r-- 1 joska joska   156 mars  24 16:45 mbox1214.h
-rw-rw-r-- 1 joska joska    44 mars  24 16:45 mbox1214.hrd
-rw-rw-r-- 1 joska joska   354 mars  24 16:45 mbox1214.rsc
-rw-rw-r-- 1 joska joska   155 mars  24 16:45 mboxwdg.h
-rw-rw-r-- 1 joska joska    44 mars  24 16:45 mboxwdg.hrd
-rw-rw-r-- 1 joska joska   348 mars  24 16:45 mboxwdg.rsc
-rw-rw-r-- 1 joska joska   156 mars  24 16:45 mboxwidg.h
-rw-rw-r-- 1 joska joska    44 mars  24 16:45 mboxwidg.hrd
-rw-rw-r-- 1 joska joska   342 mars  24 16:45 mboxwidg.rsc
-rw-rw-r-- 1 joska joska   726 mars  24 16:45 monowidg.h
-rw-rw-r-- 1 joska joska   208 mars  24 16:45 monowidg.hrd
-rw-rw-r-- 1 joska joska  1338 mars  24 16:45 monowidg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 nine_wdg.hrd
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 nine-wdg.hrd
-rw-rw-r-- 1 joska joska 11296 mars  24 16:45 nine_wdg.rsc
-rw-rw-r-- 1 joska joska  8510 mars  24 16:45 nine-wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 pas_wdg.hrd
-rw-rw-r-- 1 joska joska 11498 mars  24 16:45 pas_wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 ronb_wdg.hrd
-rw-rw-r-- 1 joska joska 11498 mars  24 16:45 ronb_wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 rondswdg.hrd
-rw-rw-r-- 1 joska joska  8506 mars  24 16:45 rondswdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 rond_wdg.hrd
-rw-rw-r-- 1 joska joska 11498 mars  24 16:45 rond_wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 styl_wdg.hrd
-rw-rw-r-- 1 joska joska 11464 mars  24 16:45 styl_wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 w98_wdg.hrd
-rw-rw-r-- 1 joska joska  8512 mars  24 16:45 w98_wdg.rsc
-rw-rw-r-- 1 joska joska    27 mars  24 16:45 win_wdg.hrd
-rw-rw-r-- 1 joska joska  8512 mars  24 16:45 win_wdg.rsc
-rw-rw-r-- 1 joska joska   753 mars  24 16:45 xaaeswdg.h
-rw-rw-r-- 1 joska joska   208 mars  24 16:45 xaaeswdg.hrd
./xaaes/xobj:
total 36
-rw-rw-r-- 1 joska joska  155 mars  24 16:45 nine-ozk.h
-rw-rw-r-- 1 joska joska   50 mars  24 16:45 nine-ozk.hrd
-rw-rw-r-- 1 joska joska 3466 mars  24 16:45 nine-ozk.rsc
-rw-rw-r-- 1 joska joska  403 mars  24 16:45 simple.h
-rw-rw-r-- 1 joska joska  120 mars  24 16:45 simple.hrd
-rw-rw-r-- 1 joska joska 3464 mars  24 16:45 simple.rsc
-rw-rw-r-- 1 joska joska  152 mars  24 16:45 style.h
-rw-rw-r-- 1 joska joska   50 mars  24 16:45 style.hrd
-rw-rw-r-- 1 joska joska 3464 mars  24 16:45 style.rsc
trecool
Postby trecool » Sun Mar 26, 2017 7:00 am
Ok. Job done!
I had to manually set the video mode in xaaes.cnf.
After that system boot to desktop. Then I set the screen using your tool and the video.cnf file created, I put back the include line and now works.
In other words, for some strange reason, xaaes didnt choose the default mode when video config file is missing...
Big fan of VanillaMint here! Thanks Joska for your wonderful job and help!
Postby joska » Sun Mar 26, 2017 8:13 am
trecool wrote:In other words, for some strange reason, xaaes didnt choose the default mode when video config file is missing...
That's strange. Is your NVRAM OK? Is there a newdesk.inf present?
BlankVector
Postby BlankVector » Sun Mar 26, 2017 9:11 am
joska wrote:- Support for Hades, CT60, Afterburner and Amiga (!).
Wow! I just tried the 040 version on WinUAE + EmuTOS, it worked out of the box :cheers:
Of course, only monochrome ST-High is supported, as usual.
I also tried it on real Amiga + Vampire V2. It worked equally well, but before that I had to rename xaaes040.km to xaaes060.km. Ideally, the Apollo 68080 should be detected as 68040, but due to the presence of PCR register is it currently detected as 68060. So xaloader.prg tries to load the wrong module. This is a known issue, I plan to provide a patch for proper Apollo 68080 detection as 68040 in FreeMiNT (already done in EmuTOS).
Note about mouse drivers: inside the xaaes folder, only one of moose.adi or moose_w.adi should be present. I think that only keeping moose_w.adi should be safe for everyone.
Great job, go ahead!
Subscribe to my Vretrocomputing channel on YouTube and Facebook.
Return to “Applications”
