Animated gif player/software
All about the serious stuff.
Elvis1990
Postby Elvis1990 » Mon Feb 13, 2017 12:08 am
Is there any software for the ST that would be able to play an animated gif from a floppy disk?
If not, is there a similar picture/animation format native to STs?
ISTR watching my friend record a moving image to his ST via a video capture device, but this was 25 years ago!
Re: Animated gif player/software
Postby exxos » Mon Feb 13, 2017 11:19 am
There is GEMVIEW, that is a universal image viewer, but I don't recall if it plays animated gif's or not.
vido
Postby vido » Mon Feb 13, 2017 12:06 pm
I think Papillon can play animated gifs.
MM41
Postby MM41 » Mon Feb 13, 2017 1:20 pm
MP_STE (viewer and video maker) can play animated GIF (slow) http://gtello.pagesperso-orange.fr/downld_e.htm (thanks Moulinaie!!!)
so the FLM format is more speed on ST,
else you can use Cyberpaint to create your own animated (but not GIF)
Postby DarkLord » Mon Feb 13, 2017 3:17 pm
That link is dead here. Goes to Suddenlink's suggestion page... :(
EDIT: But works fine when I paste into it into Firefox. Go figure...
lp
Postby lp » Mon Feb 13, 2017 7:22 pm
Unfortunately GemView will only load the first frame. zView will animate them, but its system requirements prevent it from working on a plain ST.
Postby DarkLord » Tue Feb 14, 2017 6:27 pm
Just to verify MM41's post above - Mplayer STe will indeed play animated
GIfs. Here is a short (and amateurish) video showing my Pak 68/3 equipped
STacy playing a couple of GIFs. This is at 40mhz with the output to a color
LCD.
https://youtu.be/-DkrfkePmu4
nanard
Postby nanard » Mon Dec 18, 2017 12:58 pm
Atarieterno
Postby Atarieterno » Mon Dec 18, 2017 4:40 pm
Thank you very much!
It is an excellent job.
nanard
Postby nanard » Mon Dec 18, 2017 4:54 pm
Feel free to send me some .GIF which don't display correctly :)
resolution must be maximum 320x200 with 16 used colors max.
Gif with non even width make the decoder crash (because of the C2P routine which reads words)
fmh
Postby fmh » Mon Dec 18, 2017 6:15 pm
What about a Web Browser? Doesn't CAB, Netsurf or Highwire do animated GIFs?
Atari Gamer
FireBee
Postby rockyone » Mon Dec 18, 2017 7:28 pm
Thanks, it's great
Postby rockyone » Mon Dec 18, 2017 7:52 pm
Prism Paint v1.1 loads gif - old format images - otherwise the color palette is gray -.
But Gif images created by Prism Paint are correctly loaded by your application.
Bee.gif created with Prism Paint ,
BEE.zip
Atarieterno
Postby Atarieterno » Mon Dec 18, 2017 8:22 pm
MM41
Postby MM41 » Mon Dec 18, 2017 9:46 pm
Cool another Gif Player :D , i'm going to try this :cheers:
Return to “Applications”
