HDdriver 8 language settings
All about the serious stuff.
Dark Willow
Postby Dark Willow » Fri Dec 07, 2012 8:20 pm
I'm just using HDdriver 8 to try and format an SD card for my SatanDisk, but it's a nightmare because the interface is in German. I emailed Uwe to try and get an English RSC, but he informed me the UI auto-detects the TOS language and uses that, so you can't just swap RSC files.
Is there another way to change it, to force the UI into English?
TT030, 10mb/16mb, 3.5" SCSI multi-card reader (2gb CF/512mb SD), Matrix TC1006 gfx card, EtherNEC, Epson GT scanner, VanillaMint | 1040STe, 4mb, TOS 1.62, MegaFile 60, SM125 | Lynx II | 800XL, 64k, 1050 disk drive, XC12 tape deck, MicroLink parallel adapter
PuppySoft:Projects & More
lp
Re: HDdriver 8 language settings
Postby lp » Fri Dec 07, 2012 9:32 pm
Hold down the left shift or alt or control when you start that app. Its one them as I had the same issue. It insisted on coming up in German on my Hades even with UK roms. :wink:
Dark Willow
Postby Dark Willow » Fri Dec 07, 2012 9:52 pm
Thanks! :cheers:
Postby wongck » Sat Dec 08, 2012 12:40 am
Should be CTRL key.
Saturnin51
Postby Saturnin51 » Wed Dec 20, 2017 2:31 pm
With TOS system, CTRL + double click => English version; ALT + double click => german version. With Magic this doesn't run. Has Someone an idea ?
Falcon 030-14 Mo - FDI Steinberg -Soundpool Analog 8 - SMP24 - Cubase Audio Falcon 2.06 dongle - SC55 - SG64 - Yamaha CBX-T3
Return to “Applications”
Users browsing this forum: No registered users and 17 guests
