Ghostlink v 1.02 beta and Parcp v 2.5 are join on this Sticky with their docs !
Enjoy or Comments or Upgrade !
HDD_DMN - Our last and best product which connects ATARI a PC thru parallel
port. This is most cheap way how to connect hard disc to ST/STE and this is
only one of the functions included !! Let's see some of them:
* You can use 1.44MB HD floppy on your ATARI
* You can use PC hard disc
* So you can copy files from PC to ATARI respectively thru parallel port and using your favorit copy program or DESKTOP !!
* If you have not battery clocks in your ATARI, this is way how to got it.
* INItialization file uses special script which allows you to make your own batch to run when HDD_DMN start's
muguk wrote:Definitely be interested but where to get the cables from .. I bought a laplink cable which had parallel and serial on it .. but can only connect the serial side to the PC - doesn't seem to have appropriate connectors on the cable for either PC or ST via parallel.
ijor wrote:muguk wrote:Definitely be interested but where to get the cables from .. I bought a laplink cable which had parallel and serial on it .. but can only connect the serial side to the PC - doesn't seem to have appropriate connectors on the cable for either PC or ST via parallel.
Hmm, never heard of such a cable. Are you sure it is both parallel and serial on the same cable ?
