Scanning Software Request
All about the serious stuff.
Plymouth
Postby Plymouth » Sun Jul 13, 2008 7:37 pm
Does anybody know of Atari ST scanning software that will work with the Mustek 600 CP flatbed scanner please?
Tony
nativ
Re: Scanning Software Request
Postby nativ » Sun Jul 13, 2008 7:45 pm
I've asked a similar question regards my 600p scanner. Do a search and you'll find some software and links?
Bye
Ashley
edit:
here it is:
Re: Golden Image - serial port
by [ProToS] on Sat May 24, 2008 10:20 pm
try with the demo of Sandrine app on a falcon, normaly it works for UMAX scsi 600s,610s and 1220s
perhaps the umax900s work
http://centek.free.fr/atari/softs/sandrine.zip
if i
[ProToS]
Postby [ProToS] » Sun Jul 13, 2008 8:15 pm
for a mustek you have to try novascan.
Try with this demo, if it work with your scanner I have a full app somewhere.
http://home.wtal.de/dk/archive/nova120b.lzh
nativ wrote:Hi,
Bye
Ashley
edit:
here it is:
if i
what you are looking for ? umax, mustek or golden image driver ?
for umax sandrine and scanX is the way,
for mustek novascan (and parx M&E *.rim) is the way,
for golden image touchup (and parx M&E *.rim) is the way
as I say try the demo first to see if it could work with your scanner
SeeU
[ProToS]/Facebook
nativ
Postby nativ » Sun Jul 13, 2008 9:05 pm
Me?
I have a Umax 600p and a Golden Image Hand Scanner.
So the Scanx? or sandrine hopefully will work!
Sorry for jumping in here. . .!
Thanks,
Ashley
bullis1
Postby bullis1 » Mon Aug 11, 2008 2:43 pm
Does anybody know if there are any Atari scan apps that support the parallel port? I've got a Umax 610p (I think it's model 610 anyway) and I want to try scanning mono/black&white images onto Atari ST. The scanner supports various parallel port protocols and is TWAIN compliant. It seems that many SCSI scanners are supported on Atari but I haven't found much info about parallel ones.
Any info, tips, link, etc. are appreciated!
EDIT: There is a fairly up-to-date scanning app for Atari but I can't recall its name or the company that makes it. I do know that the company is in Canada. Can anybody refresh my memory?
lp
Postby lp » Mon Aug 11, 2008 4:43 pm
Homa Systems
App name was ScanX and/or ScanX Pro.
There was another program that supported several Epson models.
Can't recall the name though.
I have never seen any devices that work on the parallel port other than printers on an ST. Maybe the port is not 100% compliant or no one wanted to spend the time to write special drivers? I'm not sure really.
bullis1
Postby bullis1 » Mon Aug 11, 2008 5:38 pm
lp wrote:Homa Systems
Yes, Homa Systems was the one I was thinking about. The site just brings up a Netfirms page about the account being canceled but thankfully google had the ScanX Pro page cached. However, it does not provide any way of trying or buying the software. Does anyone have it? Maybe someone could upload just the documentation so I can read about compatibility and requirements?
There are other parallel port devices for ST. They are mostly music or sound devices. I'm still hoping that there is parallel scanner support somewhere.
Thanks for the help so far.
[ProToS]
Postby [ProToS] » Mon Aug 11, 2008 10:32 pm
scanX img manual converted to pdf
SeeU
[ProToS]/Facebook
lp
Postby lp » Tue Aug 12, 2008 8:32 am
Related thread if you wish to contact Homa Systems.
viewtopic.php?f=15&t=13123&p=111056#p111056
bullis1
Postby bullis1 » Tue Aug 12, 2008 1:31 pm
lp wrote:Related thread if you wish to contact Homa Systems.
Wow, and I even posted in it! I remember now that I never had any luck getting a compatible graphics tablet. I may still be able to find one somewhere.
As for ScanX, it definitely only supports SCSI scanners. Too bad for me, I've never seen a SCSI scanner here that wasn't an industrial (and very expensive) model. At least I can scan on my PC.
Thanks for the help everyone.
Martinalix
Postby Martinalix » Thu Oct 09, 2008 9:58 am
I purchased the latest Scan-X Pro directly from Nima it was a pleasure doing business with him. Thanks for the info LP.
frank.lukas
Postby frank.lukas » Wed Oct 11, 2017 8:36 pm
Looking for the Novascan Software ...
TheNameOfTheGame
Postby TheNameOfTheGame » Wed Oct 11, 2017 9:30 pm
Here's a couple of versions - 1.2 and 1.26. Serial numbers are in the .NFO file.
Novascan.zip
frank.lukas
Postby frank.lukas » Wed Oct 18, 2017 8:00 am
Thanks ...
Return to “Applications”
