reading sd card under linux
caver99
Postby caver99 » Wed Jan 17, 2018 9:29 pm
I have a mist fpga with 32gb sd card with 3 partitions on it first on is my fat32 boot partition, second on is a 2gb ffs boot partition(DH0) and third is ffs 10gb partition(DH1) is there anyway to access the 2nd and trd partitions under linux so i can add my whdload files to the 10gb partition?
i can see them but cant mount them as there was meant to be AFFS file support but cant mount them or find any info to install i am using debian stretch.
kolla
Re: reading sd card under linux
Postby kolla » Thu Jan 18, 2018 9:05 pm
You need a kernel with AFFS support, and that's not really something that is typically enabled by default.
To check if your kernel already support AFFS, you can look in the meta file /proc/filesystems, that have all supported filesystems listed up...
# grep affs  /proc/filesystems
   affs
If your kernel was compiled with affs support, it most likely was built as a module, so to load the modules, you use...
# modprobe affs
Once you have a kernel with affs support, you can manually mount the affs partition, for example on /mnt if the SD card is available as /dev/sdb ...
# mount -t affs /dev/sdb2 /mnt
-- kolla
