ZX Spectrum Core - Loading
nightshadowpt
Postby nightshadowpt » Fri Aug 04, 2017 6:35 am
I have just configured an SD Card with (what I believe to be the latest) ZX Spectrum core (Release 20170712) for my MiST.
Everything seems to work quite well, except that the behavior of the "Fast tape load" seems erratic.
If it's ON, it will just load the game almost instantly (as expected), but if I turn it OFF the behavior is the same. No 3-4 minutes "slow loading" with the nostalgic colored sidebar stripes or ear bleeding noises ...
I understand I sound like a masochist, but as we all know around here, authenticity is important (or I would not be using a MiST).
Here are my other configured options for your reference:
Video Timmings: ULA-48
Scandoubler Fx: CRT 50%
Memory: Standard 128K
Features: ULA+ & Timex
Does anyone know if this is a bug, or if I'm doing something wrong?
Re: ZX Spectrum Core - Loading
Postby Sorgelig » Fri Aug 04, 2017 5:18 pm
There are fast loading (loading on 56MHz through virtual audio input) and turbo loading (injecting the data directly).
What you mentioned is turbo loading.
To use fast/normal loading you have to choose load first and only then choose the TAP from OSD. It was mentioned in read me.
nightshadowpt
Postby nightshadowpt » Fri Aug 04, 2017 7:39 pm
Sorgelig wrote:It was mentioned in read me.
[drops the head down in shame]... I missed it.
My apologies and thank you for clarifying the issue.
