Where to get Atari ST core and newbie questions
Everett1954
Postby Everett1954 » Mon Apr 10, 2017 5:46 am
I just received by MIST from Dragonbox.De and have gotten most cores to work.
However, the official GitHub does not have a downloadable Atari ST core? It has a two year old link that doesn't seem to work.
Also there appears to be a lot of conversation on correct TOS image to use, can someone help me with this also?
Do most cores use a USB joystick (like SNES) and not the DB-9 ports? Are there any cores that use the DB-9's?
Is anyone working on a channel F core?
Thanks,
Everett
jotego
Re: Where to get Atari ST core and newbie questions
Postby jotego » Mon Apr 10, 2017 10:54 am
Welcome to MiST!
The Atari ST core is actually called MiST. You can find it in github indeed. The file is the .rbf one ,10 months old as of today.
The TOS image was a problem with real ST computers too. Some software depends on specific TOS versions so if something fails, try a different TOS version first.
I cannot help you with the other questions.
Everett1954
Postby Everett1954 » Thu Apr 13, 2017 11:27 pm
I am having problems with the ST setup. When selecting Video from the OSD i only have a choice of two PAL frequencies. I am in US with NTSC.
How do I get the NTSC setting?
I do get a desktop with A&B floppy drives but how do i load a game? I have an Atari ST folder with a VROOM.ST file (I take it that is a game) but cannot load or play it.
Are there separate NTSC and PAL versions of Atari ST core?
I have the latest renamed ST core as core.rbf, tos.img (2.6), dsk_a.st and system.fnt and a folder with VROOM.ST
Do i need something else?
DrOG
Postby DrOG » Fri Apr 14, 2017 10:16 am
The video standard depends on the TOS you're using (i.e. UK means PAL, US means NTSC version).
You can insert .st floppy images into disk drives using the OSD.
Everett1954
Postby Everett1954 » Sat Apr 15, 2017 5:29 pm
Thank you for the info on the US and Pal TOS.img. Most images seem to be PAL even though they are marked as US.
What file extensions can the ST core use? .ST .STX or Zip?
Also what files extensions for the amigo core?
thanks
DanyPPC
Postby DanyPPC » Sat Apr 15, 2017 6:07 pm
For Atari ST use only ST disk images,
for Amiga use ADF files for disks or HDF for harddrive images.
NZSPY
Postby NZSPY » Wed Oct 04, 2017 5:39 am
Sorry another Newbie here.. and apologies if this has been answers somewhere else,but I've been looking but haven't found the answer yet..
Can someone please explain the "STEroids" setting ? I'm assuming this is a boosted mode of some sort ?
Also I know the DB9's can't use analog devices IE mouse or paddles, is this a hardware limitation of the board or just not implemented yet ? Will USB DB9 adapter that lets use use legacy analog devices on windows work on the MIST hardware?
SuperBabyHix
Postby SuperBabyHix » Wed Oct 04, 2017 2:09 pm
I believe the STEroids mode is just STE mode with the cpu running at 48Mhz.
I don't know anything about the analog devices though, sorry.
