ZX-UNO Spectrum FPGA
Paradroyd
Postby Paradroyd » Tue Aug 05, 2014 9:21 pm
It would be interesting to see this eventually get ported to MIST.
- Paradroyd
@paradroyd on twitter
MasterOfGizmo
Re: ZX-UNO Spectrum FPGA
Postby MasterOfGizmo » Tue Aug 12, 2014 9:58 am
How about this:
https://code.google.com/p/mist-board/so ... 2_r306.rbf
It's not the zxone core but a port of Mike Strlings core from http://www.mike-stirling.com/retro-fpga ... n-an-fpga/
It supports tape emulation via csw 1 files (http://ramsoft.bbk.org.omegahg.com/csw.html#CSW1FORMAT). These can be generated from tzx files using the tzx2wav tool. You first select "Tape Loader" from the Spectrums menu and the start tape upload using the MISTs OSD and selecting a CSW1 file on the SD card.
The core implements a spectrum 128. The MISTs joystick is mapped to a Kempston compatible implementation.
alexh
Postby alexh » Tue Aug 12, 2014 11:50 am
Paradroyd wrote:It would be interesting to see this eventually get ported to MIST.
Pretty hard as they haven't released the sources :)
MasterOfGizmo
Postby MasterOfGizmo » Tue Aug 12, 2014 4:33 pm
They are preparing a hardware release and might be afraid of competition. Only the brave place their code on google ... :-)
Jungsi
Postby Jungsi » Tue Aug 12, 2014 5:05 pm
Working good (ok only tested one game) - is there a chance to ever use *.tap files? Because the loading time really hurts :-)
Atari: 1040 ST/STFM/STE, Mega STE, Falcon, TT - GigaFile, SuperSatan, Ultrasatan, EtherNEC, NetUSBee, Unicorn, CosmosEx
Sinclair: ZX81, 48k, +48k, 128k,+2, +3, QL - DivIDE+, DivIde 2k11, Interface 1, Microdrive, Interface 2, Spectranet, Datel+D, Interface 1bis, ZXpand
http://www.jungsi.de
eeun
Postby eeun » Tue Aug 12, 2014 5:19 pm
Cool! Just loaded up Archon. I'd forgotten how long we used to wait for a game to load back in the cassette days. :coffe:
I couldn't use the tap2csw program I found, since it only works on 32-bit windows. tzx2wav works like a charm.
Thanks (once again) Till!
MasterOfGizmo
Postby MasterOfGizmo » Tue Aug 12, 2014 5:20 pm
NML32
Postby NML32 » Tue Aug 12, 2014 11:39 pm
Thanks Till for adding the ZX Spectrum.
I don't know much about the Spectrum and was wondering if there was an easy way to convert .tap to .csw format. Most of my files are in tap format.
Paradroyd
Postby Paradroyd » Wed Aug 13, 2014 4:35 am
MasterOfGizmo wrote:How about this:
This is great..thanks! Looking forward to fooling around with it.
I know very little about the Spectrum, but I'm reading up on it. World of Spectrum is a great resource.
- Paradroyd
alexh
Postby alexh » Wed Aug 13, 2014 12:29 pm
If the loading time is killing you then use OTLA. It is a tool which creates accelerated MP3's which still work thanks to the improved signal to noise ratio of modern MP3 players vs cassette players.
https://code.google.com/p/otla/
Jungsi
Postby Jungsi » Wed Aug 13, 2014 1:12 pm
alexh wrote:If the loading time is killing you then use OTLA. It is a tool which creates accelerated MP3's which still work thanks to the improved signal to noise ratio of modern MP3 players vs cassette players.
Yeah - I know OTLA - can it output also files in CSW format?
Paradroyd
Postby Paradroyd » Thu Aug 14, 2014 3:54 am
I'm using the command line utility tzx2wav to convert files. It works great, but I've only been able to get it to convert one tzx at a time. It doesn't seem to support wildcards unless I'm missing something. I've had to explicitly feed it one tzx at a time. That's a whole lot of typing. (I know, 1st world problem).
Does anyone know of a way to mass convert all tzx's in a directory at once?
- Paradroyd
breiztiger
Postby breiztiger » Thu Aug 14, 2014 5:37 am
Perhaps with a batch file (for %%f in (*.tzx) ...) :roll:
Breiztiger
alexh
Postby alexh » Thu Aug 14, 2014 12:19 pm
Jungsi wrote:Yeah - I know OTLA - can it output also files in CSW format?
It can save in WAV which can be converted to CSW. You have an app on your phone which can play CSW?
eeun
Postby eeun » Thu Aug 14, 2014 2:59 pm
Paradroyd wrote:Does anyone know of a way to mass convert all tzx's in a directory at once?
I haven't attempted batch converting many files, but I did write a small Windows .bat file so you only need to type the file name. Not as good as a mass conversion, but still faster than having to open the command line every time.
set /p Input=file to convert:
TZX2WAV.EXE -c1 %Input%
Postby Dal » Thu Aug 14, 2014 3:15 pm
If you change %input& to %1 and get rid of your set /p line, then you can just drag and drop the file to convert on top of the batch file in Windows... ;)
Paradroyd
Postby Paradroyd » Thu Aug 14, 2014 4:34 pm
Dal wrote:If you change %input& to %1 and get rid of your set /p line, then you can just drag and drop the file to convert on top of the batch file in Windows... ;)
Thanks! That's a whole lot easier.
- Paradroyd
Paradroyd
Postby Paradroyd » Thu Aug 14, 2014 4:58 pm
Expanding on that idea a bit, if you make the default action in windows for tzx files to run that batch file (via rightclick, properties, then change "opens with"), all you have to do is double click a tzw and a CSW version is created in the same directory.
- Paradroyd
NML32
Postby NML32 » Thu Aug 14, 2014 8:08 pm
Has anyone tried ULA + games? I've tried a few from the link below but haven't had any luck running them. The few that I've tried load and I get a menu screen but then crashes when I start the game.
http://www.abrimaal.pro-e.pl/zx/ulaplus.htm
Edit:
I went back and looked at Mike Strlings web page and didn't see any ref to ULA+.
I think I was confusing Mike's FPGA core with Alessandro Dorigatti.
https://sites.google.com/site/speccycores/home
:oops:
Paradroyd
Postby Paradroyd » Mon Aug 18, 2014 12:51 am
I was able to batch convert all of my tzx files to CSW in windows by doing a "dir /s /w/>c:\convert.cmd" then by using Notepad++ to do a mixture of search & replace and column edits, build a massive batch file that basically explicitly called out every tzx in the hierarchy (a LOT) and it did a "tzx2wav -c1 'filename.tzx'" for each of them. It took a while to build and it was a beast of a batch file, but it converted everything in one really long run.
Problem solved.
- Paradroyd
Postby Dal » Tue Aug 19, 2014 7:41 am
Would have been a lot faster to do something like this in a batch file:
CD c:\path\to\unconverted\tzx\files
FOR /F %%f IN (DIR *.tzx) DO c:\path\to\converter\tzx2wav.com -c1 "%%f"
you can do it straight off the command line but you'd need to use %f rather than %%f.
Jungsi
Postby Jungsi » Tue Aug 19, 2014 10:58 am
Which utility can convert from *.wav to *.csw? :-)
Paradroyd
Postby Paradroyd » Tue Aug 19, 2014 6:32 pm
Dal wrote:Would have been a lot faster to do something like this in a batch file:
More "proper", certainly, and faster for someone that knows the syntax for how to do this in Windows, which I didn't. I'll keep track of this for next time though, and at the rate cores are being released, there will certainly be a next time.
- Paradroyd
greblus
Postby greblus » Wed Aug 27, 2014 9:12 pm
MasterOfGizmo wrote:It supports tape emulation via csw 1 files (http://ramsoft.bbk.org.omegahg.com/csw.html#CSW1FORMAT). These can be generated from tzx files using the tzx2wav tool. You first select "Tape Loader" from the Spectrums menu and the start tape upload using the MISTs OSD and selecting a CSW1 file on the SD card.
Hi Till. Would it be possible to pause the tape emulation and then continue?
I've just converted a tzx which contains two sides of a tape and the game requires to stop the tape and then in certain moment continue loading on side b.
MasterOfGizmo
Re: AW: ZX-UNO Spectrum FPGA
Postby MasterOfGizmo » Wed Aug 27, 2014 9:14 pm
Yes, that shouldn't be too hard. But how do i know when to pause and when to continue?
