ACSI Drive
Bug reports and support area for Steem
Forum rules
All bug reports must include:
Steem version
Host operating system version
TOS ROM version
Copy of steem.ini
Reference to or copy of disk image being used
Brief description of steps performed
Description of desired outcome
Description of actual outcome
Diefenbaker
ACSI Drive
Postby Diefenbaker » Sat Oct 08, 2016 5:12 am
In Steem 3.8.2 (TOS 1.6.2 UK) on Win 10, I can't load this hard disk image recognized when I start up a machine. Disabling ACSI and using Pasti instead, the hard disk image is recognized and seems to work fine.
https://dl.dropboxusercontent.com/u/15667410/Games.rar
steem.rar
Re: ACSI Drive
Postby AtariZoll » Sat Oct 08, 2016 8:51 am
It works fine by me - even if my adaptations are known as destructive :mrgreen: (SSE 3.80B).
As I see by config file, you have disabled hard disks in Hard Drive settings.
English language is like bad boss on workplace: it expecting from you to strictly follow all, numerous rules, but self bending rules as much likes :mrgreen:
Re: ACSI Drive
Postby Steven Seagal » Sat Oct 08, 2016 3:30 pm
The game.img image works for me too, and indeed both GEMDOS and ACSI hard drives are disabled.
When they are enabled, the icon looks pushed in the disk manager and a hard drive icon appears in the status bar.
To toggle hard drives, right click on their icon in the disk manager, or uncheck 'disable' in the image browsers.
@AtariZoll
DisableHardDrives is for GEMDOS, Acsi for ACSI, unfortunately Acsi is in the 'Option' part, I'll change that in next release.
Diefenbaker
Re: ACSI Drive
Postby Diefenbaker » Sun Oct 09, 2016 1:14 am
Ok thanks for trying this guys ... I'm somewhat embarassed to say I think I found my problem, I was enabling ACSI correctly but it seems only to work if Pasti is completely disabled or configured for "STX only". Instead I had left Pasti enabled and only disabled the hard drive within Pasti config, and that seems not to work.
Re: ACSI Drive
Postby Steven Seagal » Sun Oct 09, 2016 7:24 am
In the ini file, Acsi was deactivated, Pasti was enabled but not the HD.
Normally it's possible to activate both Pasti and Steem's ACSI.
Haven't tried it.
I know Pasti options are a bit confusing in Steem SSE, this is indeed a point you must watch, it's a compromise.
Return to “Support”
