Reading .ST floppy images on linux
Moderators: DrCoolZic, Brume
scruss
Postby scruss » Mon Nov 09, 2015 4:16 am
Hi - I'm trying to access and archive files from within .ST disk images stored on TOSEC: Atari ST. Although Hatari can read all of the disk images I've tried, I can't get reading and copying to work reliably with mtools.
Am I right in thinking that the .ST format is just a cylinder-by-cylinder dump of the disk image? If so, I'd expect the files to be either 368640 bytes (SS DD) or 737280 bytes (DS DD). But they're not all that size. Just in one folder, there are images of the following sizes:
  • 368640 bytes (Heads: 1 Cylinders: 80 Sectors: 9?)
  • 373248 bytes (Heads: 1 Cylinders: 81 Sectors: 9?)
  • 377856 bytes (Heads: 1 Cylinders: 82 Sectors: 9?)
  • 409600 bytes (Heads: 1 Cylinders: 80 Sectors: 10?)
  • 450560 bytes (Heads: 1 Cylinders: 80 Sectors: 11?)
  • 737280 bytes (Heads: 2 Cylinders: 80 Sectors: 9?)
  • 746496 bytes (Heads: 2 Cylinders: 81 Sectors: 9?)
  • 755712 bytes (Heads: 2 Cylinders: 82 Sectors: 9?)
  • 819200 bytes (Heads: 2 Cylinders: 80 Sectors: 10?)
  • 901120 bytes (Heads: 2 Cylinders: 80 Sectors: 11?)
Only some of the DS DD sized images are readable with mtools. Are there any mtools configs out there that could reliably read these images, please?
leech
Re: Reading .ST floppy images on linux
Postby leech » Thu Jun 23, 2016 4:33 am
You're over thinking this.
username@localhost:~/Documents/Atari % sudo mount -o loop hddriver.st /mnt/
[sudo] password for username:
username@localhost:~/Documents/Atari 2s % ls /mnt
AUTO          CONTRIB  HDDRCONF.CPX  HDDRUTIL.INF  LIESMICH  XHDI
AUTOPARK.ACC  FIXES    HDDRUTIL.APP  ICONS.RSC     README    ZIPCTRL.CPX
Granted, I think you have to have mtools installed. But yeah it's as simple as mounting the image with -o loop
Jeff_HxC2001
Postby Jeff_HxC2001 » Sun Jul 10, 2016 2:52 pm
You can also use the hxc software to browse ST/MSA/STX/Whatever images.
To build it for linux : https://sourceforge.net/projects/hxcfloppyemu/
scruss
Postby scruss » Sun Aug 14, 2016 6:13 pm
leech wrote:You're over thinking this.
Okay then:
$ sudo mount -t msdos -o loop,ro FaST_Club_Mono_Clip_Art_661.st /mnt/scratch/
mount: wrong fs type, bad option, bad superblock on /dev/loop1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
Maybe you were under reading the question? This is not about simple HD images, it's about ST floppy images, in all their weird sizes.
The hxc software is a nice idea, thanks, but I need something from the command line. I have potentially hundreds of floppy images to convert.
leech
Postby leech » Sun Aug 14, 2016 10:41 pm
leech@localhost:~/Documents/Atari 1 % sudo mount -o loop Gauntlet.st /mnt/
[sudo] password for leech:
leech@localhost:~/Documents/Atari 2s % ls /mnt
AUTO          GAUNT_ED.PRG  LEVEL.DAT   MR_DEATH.SPR  TITLE.PI1
DEMON.SPR     GAUNT_ED.TXT  LEVEL.DIR   MUSIC.DAT     VALKYRIE.SPR
ELF.SPR       GHOST.SPR     LOBBER.SPR  RAND.BIN      WARRIOR.SPR
GAUNT_ED.DAT  GRUNT.SPR     MIDI.PRG    SORCERER.SPR  WIZARD.SPR
leech@localhost:~/Documents/Atari %
That's what I meant by over thinking it. On most modern Linux systems, it'll automatically figure out the file system for you. Granted this won't work with all of the disk images, since there are always those that don't have typical Atari TOS or msdos style formats.
Hmm, I'm guessing this image is one of those in the funky format.
[64866.927738] FAT-fs (loop0): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[65496.210161] FAT-fs (loop0): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
leech
Postby leech » Sun Aug 14, 2016 10:59 pm
Interesting thing here as well. Another
file AHDI.st
AHDI.st: DOS/MBR boot sector, code offset 0x30+2, sectors/cluster 2, root entries 112, sectors 1440 (volumes <=32 MB) , Media descriptor 0xf9, sectors/FAT 5, sectors/track 9, dos < 4.0 BootSector (0x0), FAT (12 bit by descriptor)
disktype AHDI.st
--- AHDI.st
Regular file, size 720 KiB (737280 bytes)
FAT12 file system (hints score 3 of 5)
  Volume size 711 KiB (728064 bytes, 711 clusters of 1 KiB)
file FaST\ Club\ Mono\ Clip\ Art\ 661\ \(19xx\)\(FaST\ Club\).st
FaST Club Mono Clip Art 661 (19xx)(FaST Club).st: data
disktype FaST\ Club\ Mono\ Clip\ Art\ 661\ \(19xx\)\(FaST\ Club\).st
--- FaST Club Mono Clip Art 661 (19xx)(FaST Club).st
FAT12 file system (hints score 1 of 5)
Hatari doesn't have a problem reading the disk.
Postby joska » Mon Aug 15, 2016 7:10 am
leech wrote:That's what I meant by over thinking it. On most modern Linux systems, it'll automatically figure out the file system for you. Granted this won't work with all of the disk images, since there are always those that don't have typical Atari TOS or msdos style formats.
My experience is that Linux struggles with most floppy images (or real floppies for that matter) that are not straight DOS or TOS formatted. There's a lot of "strange" disks out there - coverdisks which are both single- and double-sided at the same time, PD library disks with "antivirus" bootsectors, lots of disks formatted with broken formatters...
I prefer to use Hatari to access disk images. If the OP needs to extract the files from a large number of floppies I suggest using a shell like Mupfel and write a simple script for it.
leech
Postby leech » Mon Aug 15, 2016 2:23 pm
Yeah, I think this is the case here. hatari sees the files just fine, and as shown, disktype even shows the same size of the .st image for one that works and the one in question that doesn't.
Also, I'm not seeing anywhere how to build the HxC tools for Linux. I ended up ordering two of them this week (one for my Falcon, and another for my Amiga 4000D, I'm getting tired of floppies just starting to error out on me for no reason).
Edit: nevermind, I see this post; viewtopic.php?f=99&t=29580 When I tried yesterday, I couldn't find the correct source tree/zip file.
scruss
Postby scruss » Tue Aug 16, 2016 12:58 am
joska wrote:I prefer to use Hatari to access disk images. If the OP needs to extract the files from a large number of floppies I suggest using a shell like Mupfel and write a simple script for it.
Thanks; that looks a potentially useful path. I don't see a way to auto-mount different floppy images inside Hatari, or to quit the emulator from inside a script. I don't have time for pointing and clicking over hundreds of images, so I'll likely just give up on the project.
What I was planning to do:
  • For each disk image:
    • Start Hatari with the disk image mounted as A:
    • Auto-run a program to recursively copy all of A: to a folder on the virtual disk C:
    • Quit Hatari automatically once the copy was finished
    • From outside Hatari, modify the script/program that is auto-run to write to a different folder on C:
