Resetline into rPi for programmatic resetting
Gunstick
Postby Gunstick » Sat Apr 30, 2016 6:12 pm
everyone does the double reset after power on as the CE takes longer to boot.
Also some people would like to be able to reset the ST from the raspberry.
Well if the reset line is connected to a GPIO pin, this becomes possible.
When powering on, and the raspberry is not yet booted, it holde the line down, thus preventing the ST from booting.
As soon as boot is finished, toggle the GPIO pin, and reset line is freed, the ST boots, loads drivers and mounts drives.
I tried it by holding the reset buttun until I see the blue LEDs flash, and the basic principle works.
If anyone is interested, I will document my building process, so you can replicate it.
I have a rPi B+ with the longer GPIOs. I currently don't know if I can use some of the normal ones (need to study the pin layout) but I tend towards using the new pins as they are a bit easier to access.
And maybe later I'll see if I can add a cold reset.
And a little battery buffer so the raspberry can do a proper shutdown.
Jookie
Re: Resetline into rPi for programmatic resetting
Postby Jookie » Sat Apr 30, 2016 11:37 pm
Gunstick wrote:everyone does the double reset after power on as the CE takes longer to boot.
Nice hack :) The other option would be trying to reset the ST through the ACSI port - it has a RESET line there, it's connected to the chips in CE, currently it's read only (input), but with some software change it could possibly reset your ST through this line, so maybe even no hardware change is needed, just a software and firmware one. But as I'm busy with other stuff, I'm not going to try this in the next weeks...
Jookie
SweYC
Postby SweYC » Wed Feb 01, 2017 3:17 pm
any progress on reset hacks. I am very interested, but i just saw the thread :
Janez
Return to “CosmosEx”
