SCP image format addition
JimDrew
Postby JimDrew » Fri Nov 21, 2014 4:57 pm
I added a new field in the SCP image file format. My downloads page (http://www.cbmstuff.com/downloads.htm) has the latest data available.
I defined BYTE $000A as IFF_HEADS. This value has always been 0 (reserved). The value now represents the heads that are in the image file:
0=both heads
1=side 0 (bottom head)
2=side 1 (top head)
I did this because there is a big interest right now in Atari 400/800 disks, and it seems silly to image both sides of a single sided disk. I am changing the copier so you can select the heads to be used, and the Atari 400/800, TRS-80, TI-99/4A, and CP/M will default to a single side. You will be able to select 0, 1, or both heads. So, Atari ST disks that are single sided could be imaged that way to save disk space.
I am the flux ninja
