Mist and Dell U2412m
Marmes
Postby Marmes » Tue Apr 18, 2017 10:46 pm
Hi!
I have a mist and a Dell U2412M, it supports 15Khz. When I load the selector core, it doesn't do anything. I checked the cfg file, and it works on other monitor, does any one had this experience with a similiar monitor? For my mist to work I need to load the core I want directly otherwise it won't display.
Cheers!
DrOG
Re: Mist and Dell U2412m
Postby DrOG » Wed Apr 19, 2017 2:50 pm
You don't need to load the 'selector' core, almost every core has the option to change the FPGA core using the F12-menu (or pushing the middle button on the device itself) - there are some exceptions, i.e. the Atari 800, the PC Engine, the MSX and most arcade cores, see this spreadsheet: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
I recommend to boot your system using a core.rbf default which has a VGA-standard compatible video output (640x480@60Hz).
Later you can choose other, less VGA compatible cores from the menu (i.e. PAL-standard: 720x576@50Hz), and switch the 15kHz/31kHz sync option pressing long the middle button on the device, if you have one of the latest firmware (or change the scandoubler_disable option in mist.ini: https://github.com/mist-devel/mist-board/wiki/DocIni ).
Important: in 15kHz mode the HSync and VSync signals are merged on VGA pin 13 to CSync (original HSync pin), and VGA pin 14 (the original VSync) gives an RGB switch signal, suitable for 'minimig VGA2SCART cable'. See the details here: https://github.com/mist-devel/mist-boar ... ScartCable
Perhaps the problem is that this is not what your Dell monitor expects in 15kHz mode (it needs probably separated HSync and VSync signals).
You can try a 'Sync-on-Green' cable instead: https://github.com/mist-devel/mist-boar ... PbPr_Cable
Marmes
Postby Marmes » Wed Apr 19, 2017 7:50 pm
Ok, Thanks! I will do the way you suggest.
Cheers!
DrChaos
Postby DrChaos » Mon Apr 24, 2017 8:15 am
A other option could be a SynSplitter. I'll try to build such cable/adapter for VGA2VGA...
