Handheld MiST?
Handheld MiST?
Postby Dal » Thu Mar 23, 2017 9:00 am
Just floating the idea - how feasible would it be to condense the MiST into a handheld form factor complete with a battery, screen and integrated controller?
vebxenon
Re: Handheld MiST?
Postby vebxenon » Thu Mar 23, 2017 9:10 am
Handheld or for me, even better, a MiST laptop :-)
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
Re: Handheld MiST?
Postby joska » Thu Mar 23, 2017 10:25 am
Dal wrote:Just floating the idea - how feasible would it be to condense the MiST into a handheld form factor complete with a battery, screen and integrated controller?
I actually started on this a couple of years ago. MiST with 12" LCD screen, touch overlay, battery and controller. It never got finished though, as I realised that it became much too big to be comfortable to use. Also, controls was a problem. There are so many different controller schemes, it was difficult to find a userfriendly solution to cater for "all" games. E.g. Head over Heels for the MSX use a lot of keys, but totally different keys than e.g. Gradius for the same platform.
A laptop is probably a better solution.
Edit: Early iteration of the prototype :D Here you can see the MIST board, LCD controller, amplifer and speakers and a PicoPSU. I later replaced the PicoPSU with a small switching PSU and a 7.2V 5Ah RC battery.
Re: Handheld MiST?
Postby Dal » Thu Mar 23, 2017 11:02 am
The controls are the limiting factor here. Clearly not all cores or games would be suitable for portable use - you can forget flight simulators or using GEM / Workbench / etc. However if you integrated a regular SNES / Megadrive type controller along with some control buttons for the MIST, you would be able to play most games for the console cores and any joystick-based games for the computer cores. Something along the lines of the Vega?
Re: Handheld MiST?
Postby joska » Thu Mar 23, 2017 11:22 am
Yes, this is not a very difficult project if you can accept limited controls.
Re: Handheld MiST?
Postby Dal » Thu Mar 23, 2017 11:33 am
The tough part is condensing the board into something much smaller and less power consuming. That's where specialist knowledge is needed.
Re: Handheld MiST?
Postby joska » Thu Mar 23, 2017 11:43 am
Not sure if it can be less power consuming. After all, it's just an FPGA, a microcontroller and some RAM. Also, the size isn't a big problem. What would be helpful though is if the MIST could interface directly with the screen. That would save both space and power.
