Bomb Jack Arcade : Has someone tried to port this to the MiST ?
jerome777
Postby jerome777 » Mon Mar 13, 2017 12:46 pm
Hello to all VHDL, Verilog coders and MiST users !
Has someone ever tried to port this ?
http://papilio.cc/index.php?n=Playground.BombJack
There is a YouTube video on the page (part 5), but also the four parts before, showing the progression (made in 2012) :
https://www.youtube.com/user/d18c7db/videos
There is a section "Limitations" at the bottom the page : the use of 32 BRAM blocks, will probably make things harder.
Re: Bomb Jack Arcade : Has someone tried to port this to the MiST ?
Postby Newsdee » Tue Mar 14, 2017 1:24 am
I think the problem is the MiST SDRAM is not fast enough to multiplex ROM data.
Postby Sorgelig » Tue Mar 14, 2017 6:42 am
MiST FPGA has 66(or 69? i forgot) BRAM blocks, although you can't compare BRAM blocks from different FPGA chips.
Postby ijor » Tue Mar 14, 2017 12:19 pm
Xilinx BRAM (18 Kbit) is twice as big as MiST FPGA M9K. The problem as Newsdee is saying, might be external SRAM vs DRAM.
jotego
Postby jotego » Tue Mar 21, 2017 5:19 pm
But it doesn't mean Bomb Jack cannot be done on MiST, right? It's just that particular implementation which has issues on MiST
Postby ijor » Wed Mar 22, 2017 12:07 pm
jotego wrote:But it doesn't mean Bomb Jack cannot be done on MiST, right? It's just that particular implementation which has issues on MiST
Very difficult to tell without more details. But I can certainly conceive a similar hardware that won't fit on the MIST. If you have many subsystems each one accessing its own RAM or ROM at the same time, you might have a problem. As long as you have enough internal RAM it's ok. But otherwise, external DRAM might not be able to reproduce the behavior.
You can access only a single external RAM address at a time, and DRAM (contrary to SRAM) has a substantial latency for random access. MIST DRAM has a much faster bandwidth than old school memory. But depending on the case it might not be enough to compensate.
