Broken MiST
palamzy
Broken MiST
Postby palamzy » Tue Mar 07, 2017 8:43 am
My MiST stopped working when I was using it :( The red light goes on and seems to blink three times (twice, if the first time the light goes on doesn't count).
I checked the SD card and nothing is wrong with it. I even tried formatting and re-copying everything over to it. Then I tried a second SD card with the same result.
I have no idea what to do. Can anyone help?
NML32
Re: Broken MiST
Postby NML32 » Tue Mar 07, 2017 10:24 am
You might be having the same problem as me. viewtopic.php?f=101&t=31267
When my card reader wasn't working the red light would just blink.
palamzy
Re: Broken MiST
Postby palamzy » Tue Mar 07, 2017 8:52 pm
Thanks. I suppose I can pop open the case and have a look. Did you get your MiST from Lotharek? I don't know if that makes any difference but I'm curious.
NML32
Re: Broken MiST
Postby NML32 » Tue Mar 07, 2017 9:02 pm
I did and mine is a few years old.
