USB mouse not recognized
sblendorio
Postby sblendorio » Sun Feb 12, 2017 6:19 pm
Hi, I have a nice USB mouse which is not recognized my MinimigMist. What kind of information can I report to try understanding why?
Those are device-related USB info I got from Windows... Hope it could help finding infos...
sblendorio
Re: USB mouse not recognized
Postby sblendorio » Tue Feb 14, 2017 11:16 am
I got the following output from USB debug: I started AtariST with no mouse connected, then I turned on Debug on USB, then I connected, then disconnected the mouse
key 0x28 break: 0x1C
key 0x29 make: 0x1
key 0x29 break: 0x1
key 0x29 make: 0x1
key 0x29 break: 0x1
OSD is now invisible
status change on port 1, 0x10100
Status of port 1:
 powered
Changes on port 1:
 connected
 port 1 disconnect!
usb_release_device(parent=1, port=1
status change on port 1, 0x10301
Status of port 1:
 connected
 powered
 low speed
Changes on port 1:
 connected
 dev 1: port 1 connect!
resetting port 1
status change on port 1, 0x100303
Status of port 1:
 connected
 enabled
 powered
 low speed
Changes on port 1:
 reset
 port 1 reset complete!
usb_configure(parent=1 port=1 lowspeed=1)
using free entry at 2
Setting addr 3
usb_set_addr(new=3)
failed to assign address
Status of port 1:
 powered
Changes on port 1:
 connected
 port 1 disconnect!
Postby Sorgelig » Tue Feb 14, 2017 12:26 pm
USB stack on MiST is pretty simple and limited due to MCU firmware size limit. If mouse doesn't work then i'm afraid it won't be fixed. Find another mouse. Simpler mouse has more chance to be recognized. Anyway, only 2 buttons will be supported on any mouse.
hubersn
Postby hubersn » Tue Feb 14, 2017 3:38 pm
Sorgelig wrote:USB stack on MiST is pretty simple and limited due to MCU firmware size limit. If mouse doesn't work then i'm afraid it won't be fixed. Find another mouse. Simpler mouse has more chance to be recognized. Anyway, only 2 buttons will be supported on any mouse.
Really? 3 Button mouse works nicely on Archimedes Core with RISC OS.
Have fun
hubersn
Postby Newsdee » Tue Feb 14, 2017 4:59 pm
there is a mist.ini setting to enable "boot mode" for mice, try turning it on and see if it helps (I forgot the name but its in the source code of the fw)
