USB Controllers - Why do so many not work? can we help
Higgy
Postby Higgy » Tue Jan 31, 2017 8:23 pm
As per subject really. I have 4 USB controllers, with only 1 working. They either don't work or even block my USB keyboard from working?
Generic Chinese NES pad - Not working
Generic Chinese SNES pad - Not working
Speedlink Competition Pro - Not working :(
Datel Arcade Stick (has PS3/PC & X360 modes) - works
These controllers work on Raspberry Pi. Is there anything forum members can do to improve the Firmware's compatibility?
goran
Re: USB Controllers - Why do so many not work? can we help
Postby goran » Tue Jan 31, 2017 8:46 pm
Hi Higgy,
Is this the model that is working OK: http://www.ebay.ie/itm/Xbox-360-PC-PS3- ... 465d2b66bd
Are You happy with it?
Best regards,
Goran
Higgy
Postby Higgy » Tue Jan 31, 2017 9:07 pm
Hello Goran,
Yes that is the model. It feels a solid unit and there are quite a few buttons. The main fire buttons are not micro switched, but there are upgrade guides if you later want to upgrade components.
Slade
Postby Slade » Wed Feb 01, 2017 1:20 am
Do they show up as joysticks in a Windows machine ? And do they show in the joystick test menu on the MIST at all ?
Postby Newsdee » Wed Feb 01, 2017 5:32 am
This is odd. I have a Speedlink Competition Pro USB and it was working. I'll try again.
Do you have anything unusual on your MiST by any chance, e.g. are you using the DC power jack instead of USB?
Higgy
Postby Higgy » Wed Feb 01, 2017 8:26 am
I believe they show up as joysticks in Windows, I might have only tried the 2 Chinese controllers on a Raspberry Pi.
Nothing unusual in the MiST. Powered by USB phone charger 5V 1A.
Only the Datel Arcade Stick showed 'USB' in the Joystick menu. Everything else just showed 'Atari D-9'. I will do some more tests, wife and baby permitting :D
MasterOfGizmo
Postby MasterOfGizmo » Wed Feb 01, 2017 10:05 am
I actually use one of these competition pro sticks as my primary joystick on the MIST. And it works just fine. I also have a few cheap NES and SNES pads and they also just work fine as you can see here: https://www.youtube.com/watch?v=5qCA4O-mI8A
Actually all of the joysticks and gamepads i own do work as expected. It's odd that you seem to have major problems ...
Higgy
Postby Higgy » Wed Feb 01, 2017 10:26 am
Ah great :( - issues with USB and the Archimedes core :( Why me!
Ok, just in case. - It does not matter which USB port to use? and there is no reason why I should not have a USB Keyboard + USB Mouse + USB Controller plugged in at the same time?
I am using the firmware included with - minimig-mist_1_2_2_beta.zip
MasterOfGizmo
Postby MasterOfGizmo » Wed Feb 01, 2017 11:13 am
I shouldn't make a difference which port you use and how man other devices are connected. But it doesn't hurt to check if e.g. unplugging any of the other devices solves your problem. It seems you _have_ some problem and we need to figure out where it originates from.
And i haven't tested the firmware that comes with the minimig 1.2.2 but i am pretty confident that it doesn't include any USB changes.
Postby Newsdee » Wed Feb 01, 2017 12:44 pm
Basically any controller compatible with raw USB HID should work. Those that require special drivers or handshake with the devixe (like the XBox ones) won't work. In my experience cheap generic pads and "PS3 compatible" sticks usually use HID.
Postby Newsdee » Wed Feb 01, 2017 1:53 pm
Just tried my Speedlink Competition Pro and it works just fine. Using fw version 170114.
Higgy
Postby Higgy » Wed Feb 01, 2017 5:30 pm
I just done some more testing.
Controllers work in Windows.
From the sticker underneath, my Competition Pro is a 'SL-6602-TBE'. While plugged into the MiST it even locks up the USB ports so keyboard etc don't work?!
I found another USB controller, a SEGA Saturn chinese clone and most of the buttons on that are registered, apart from A & C!
Higgy
Postby Higgy » Wed Feb 01, 2017 5:34 pm
Just remembered I have a wired PS3 clone.
Does not work :( but when I hot plug it in Joystick config I get USB ....[] appear. Although no buttons are recognised.
Postby Newsdee » Sun Feb 05, 2017 2:40 am
goran wrote:Anybody tried Hori Arcade Stick with MIST?
My RAP4 VLX works great :D
But be warned: it's a multi standard PS3/PC/XBox stick rather than XBox; don't get XBox only as it will probably not work.(the reason is XBox controllers have an extra chip/encryption so they only work of MS licensed platforms)
goran
Postby goran » Sun Feb 05, 2017 8:59 am
So maybe Hori Fighting Stick Mini 4 will work, wich is also PS3/PS4/PC...?
https://www.youtube.com/watch?v=ETxu9ZqM2aI
Higgy
Postby Higgy » Sun Feb 05, 2017 8:07 pm
I spent an hour testing today.
I did get the SNES and NES pad to be recognised and could test them in the OSD menu.
Unfortunately turning off the MiST and on again i lost the controllers. I could not get them detected again.
It all seems very random if it is going to work or not?
I have used 4 power supplies, 3 screens, 2 keyboards and a whole load of crossed fingers, but it is still no good (also tried different Firmware revisions).
What could be the problem?
