Most wanted new MIST cores (possible poll)
Re: Most wanted new MIST cores (possible poll)
Postby Newsdee » Fri Oct 07, 2016 1:21 am
Is a Neo geo even possible with the current board? Not sure, apparently the original has 4 separate banks of RAM so some serious multiplexing would be needed.
vebxenon
Postby vebxenon » Fri Oct 07, 2016 8:29 am
foobar wrote:As an option - Soviet PDP-11 compatible computer "UKNC" - https://en.wikipedia.org/wiki/UKNC
Sorgelig has done several Soviet computer cores https://github.com/sorgelig?tab=repositories ... BK0011M, Apogee BK-01, Specialist/MX and Vector 06, so that core could be possible :D :cheers:
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
jotego
Postby jotego » Fri Oct 07, 2016 8:37 am
retrorepair wrote:I second X68000 and would definitely like to see more arcade cores, donkey kong etc would be the obvious choices but I wonder if CPS1 would fit on the MIST? That would obviously open up games such as Final Fight, Street Fighter 2, Punisher etc.
To be honest, there are many arcade platforms that support multiple games.
-Sharp X68000 is high on my list. I am about to release the YM2151, which is the sound chip of the Sharp. The other big thing is the video, which was quite complex with sprites, scroll, etc...
-Capcom System 1, which also makes use of the YM2151
-Sega System 16, yet one more arcade platform with YM2151
-NeoGeo, although due to memory limitations of the MIST not all games would work. I think we can get Metal Slug in, though.
And, as a developer, what I really want to see is a poll with +100 voters so I can take it to direct my work. After the YM2151 I am considering which Yamaha chip to do next: that of the Megadrive? the Sound Blaster one? The Master System chip? So a poll showing users wishes would definitely help me.
RobertK
Postby RobertK » Mon Oct 10, 2016 12:53 pm
Ok, I have just started the polls, four qualifying rounds with 9 competitors each. They run from now on for 10 days, with three options per user. I have added four more systems to fill up the field, including the Apple I. I first thought that it contains some TTL logic, but according to here it should be doable on FPGA.
I have picked the systems randomly (using a little program that I have written), but before that I took four "main contenders" (IMHO) and put them into separate groups, so that they don't all show up in the same group.
Happy voting...
KrisAmiga
Postby KrisAmiga » Mon Oct 10, 2016 2:45 pm
Sega Genesis
SNES
Amiga AGA V1.3
Commodore 128
917k
Postby 917k » Tue Oct 11, 2016 5:54 am
TRS-80 Color Computer 3
TRS-80 Model I/III/4
Postby Newsdee » Tue Oct 11, 2016 6:00 am
how are you going to select them for the next round? top 18 by number of votes?
sebdel
Postby sebdel » Tue Oct 11, 2016 8:34 am
Sooo, who is buying a MiST to turn it into a IBM PC XT?
vebxenon
Postby vebxenon » Tue Oct 11, 2016 8:47 am
sebdel wrote:Sooo, who is buying a MiST to turn it into a IBM PC XT?
Well, some people instead of playing C=64, Amiga, MSX, etc... played using IBM PCs and compatibles, specially under MS-DOS. There is a PC core around there... http://opencores.org/project,zet86
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
RobertK
Postby RobertK » Tue Oct 11, 2016 9:11 am
Newsdee wrote:how are you going to select them for the next round? top 18 by number of votes?
Unfortunately a poll can only have up to 10 options.
I would say that the top two of each group, and the two best total runner-ups by votes qualify for the final round.
Or would you favour having the best ten by votes in the final?
Maybe we could also make a "consolation round" for the best runner-ups that did not qualify for the final.
I am looking forward to the day when I power up my MIST XT for the first time...
The perfectly correct timing (mainly for playing old CGA games) in combination with the correct display of the CGA palette and scanlines (I love them on a CRT monitor!) will raise some childhood memories for me...
Postby Newsdee » Tue Oct 11, 2016 9:23 am
RobertK wrote:I would say that the top two of each group, and the two best total runner-ups by votes qualify for the final round.
The problem won't be the top ones but those on the edge.
Maybe do both and we vote to rank the common top X between both methods (which are clearly the most wanted) then we do a second poll to rank the rest of the runner ups.
RobertK
Postby RobertK » Tue Oct 11, 2016 11:24 am
Or we could take the top five of each round and put them into two "semi final" rounds with ten competitors each? And from there the top five would qualify for the final round.
I think this would be a good approach, as long as the users don't get tired of too much voting...
1st1
Postby 1st1 » Tue Oct 11, 2016 11:59 am
Based on the IBM 5150 I would also love to see an Olivetti M24 (also known as AT&T 6300, Xerox 6060, Logabax Persona 1600) core. This PC (8086-8, enhanced CGA) is very well documented on schematic / logic level, the full "Theory of Operations" manual with TTL logics description, PAL/GAL listings is preserved online at the bitsavers. It even could be enhanced to M24SP (8086-10, 16 colors at 640x400) just by increase clock and enhance video memory. The M24 with its enhanced graphics and the "keyboard mouse" (similar to the one on ATARI ST) is also well supported by GEM and early versions of Windows and many other software.
Anyhow, a good compatible IBM PC/XT would be nice besides all the other things.
The good thing on XT class computer is that besides the CPU only FDC (NEC upd765, as in CPC), 6845 CRT controller (CGA chipset) and 82xx chips (for serial, paralle and keyboard) needs to be done and I think some of them aready exists as VHDL replacement.
sebdel
Postby sebdel » Tue Oct 11, 2016 12:22 pm
My apology for looking down on the PC XT :)
Anyway, regarding the poll, it would be good enough to come up with a roughly ranked list imo. There are not so many core developers out there, and everyone has his own priorities (not to mention skills).
Postby Newsdee » Tue Oct 11, 2016 1:05 pm
I don't mind voting more but it would make things quite long. Then again, what's the rush? :)
vebxenon
Postby vebxenon » Wed Oct 19, 2016 11:43 am
How are running the pools?
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
RobertK
Postby RobertK » Wed Oct 19, 2016 1:17 pm
Just open the topics to see the current standings: poll 1, poll 2, poll 3, poll 4. If you haven't voted yet, please do so now. Voting for this round will end tomorrow.
As we have discussed earlier, we will stage two semi final rounds for which the best five of each group will qualify.
To speed things up, seven days of voting should be enough this time and for the final.
In case of a tie (as we have it currently in poll 2 for 5th place) I will decide the qualifier by coin flipping.
vebxenon
Postby vebxenon » Wed Oct 19, 2016 9:00 pm
Yes, I voted 9 days ago ;) Thanks for the answer :)
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
RobertK
Postby RobertK » Thu Oct 20, 2016 2:50 pm
Qualifying is over now. Here are the results (qualifiers for the semi final are in bold):
Poll 1
IBM PC/XT: 32 - 31%
Apple IIGS: 22 - 21%
Tandy TRS-80 Color Computer 3: 14 - 14%
Sega SG-1000: 10 - 10%
Tandy TRS-80 Color Computer 1/2: 7 - 7%
Jupiter Ace: 6 - 6%
Memotech MTX512: 6 - 6%
Soviet computers (various, e.g. UKNC): 4 - 4%
Robotron computers (various, East Germany): 2 - 2%
Poll 2
Nintendo SNES: 39 - 34%
Sharp X68000: 25 - 22%
Arcade Systems (various): 20 - 17%
NEC SuperGrafx: 17 - 15%
Cray supercomputer: 5 - 4%
Sinclair ZX-80: 5 - 4%
NEC PC series (PC-8000 to PC-9800): 4 - 3%
VTech Laser 110 / 200 / 210 (a.k.a. Dick Smith VZ 200 / Texet TX8000 / Salora Fellow): 1 - 1%
Interton VC 4000 / Hanimex HMG 1292/1392 (and other 1292-based consoles): 0 - 0%
Poll 3
Sega Genesis / Mega Drive: 39 - 31%
Commodore 128: 20 - 16%
Atari 7800: 19 - 15%
Commodore 65: 11 - 9%
Mattel Intellivision: 10 - 8%
CP/M Machines : 9 - 7%
Thomson TO7 / TO7/70 / MO6 (a.k.a. Olivetti Prodest PC128): 9 - 7%
Oric 1 / Atmos: 5 - 4%
Apple I: 2 - 2%
Poll 4
Texas Instruments TI-99/4A: 20 - 22%
Acorn Electron: 19 - 21%
Dragon 32: 18 - 20%
Enterprise 128: 12 - 13%
Tandy TRS-80 Model I/III/4: 9 - 10%
Commodore PET / CBM-II: 7 - 8%
Sharp MZ-700: 4 - 4%
VTech Creativision: 1 - 1%
Tandy TRS-80 MC-10 / Matra Alice: 0 - 0%
The Cray Supercomputer qualilfied by coin flipping decision (bad luck, as I would have preferred the ZX-80 :D).
I will soon start the two semi final polls, again with three options per user, but this time active for only seven days.
Postby Newsdee » Thu Oct 20, 2016 3:01 pm
Bring it on. I'd expect the top 3-5 to remain the same, but it will be interesting to see how the other ones will rearrange themselves in the ranks.
sebdel
Postby sebdel » Sun Oct 23, 2016 9:28 am
I discovered the entreprise 128 only recently. It's really interesting hardware. It's probably the most advanced z80 based system ever.
The custom Asics for gfx and sound would be an interesting challenge to say the least (to me they would be).
DrOG
Postby DrOG » Sun Oct 23, 2016 10:45 am
Altough originally it's a British construction, this machine was very popular in Hungary in the late '80s and early '90s (for the same reason as the Plus4: it was cheap but strong HW).
The two main pages related to this computer (mainly in hungarian, sorry for this, Google translate may help):
http://ep128.hu
https://enterpriseforever.com
guidol
Postby guidol » Sun Oct 23, 2016 12:55 pm
DrOG wrote:Altough originally it's a British construction, this machine was very popular in Hungary in the late '80s and early '90s
see also https://en.wikipedia.org/wiki/Enterprise_(computer) ==> Development
ryan
Postby ryan » Mon Oct 24, 2016 5:30 pm
I suspect Sharp X68000 core would be too much for the FPGA that's in there now. Lots of heavy duty custom chips in the X68000. But I'd love to be proven false.
I vote for SNES.
matej
Postby matej » Mon Oct 24, 2016 5:41 pm
There is new Czechoslovak ZX Spectrum core - Didaktik M / Didaktik Kompakt
http://oldcomp.cz/viewtopic.php?f=112&t=4617
cron
