fpga64 can someone test a demoscene demo?
ericgus
Re: fpga64 can someone test a demoscene demo?
Postby ericgus » Thu May 26, 2016 7:12 pm
with the mist.ini
15khz mode this is what happens to my monitor... :-(
NML32
Postby NML32 » Thu May 26, 2016 7:14 pm
Postby Sorgelig » Thu May 26, 2016 7:32 pm
I strongly suggest to NOT use scandoubler.
duhproject
Postby duhproject » Thu May 26, 2016 7:56 pm
Sorgelig wrote:I strongly suggest to NOT use scandoubler.
I'm not using a MIST.INI file at all on mine. Should I be with this core?
NML32
Postby NML32 » Thu May 26, 2016 8:41 pm
I too get a blank screen in NTSC mode using my native NTSC monitor that can display both NTSC and PAL.
PS: Thanks for the latest core that adds the option for Jiffy DOS.
Postby Sorgelig » Thu May 26, 2016 9:07 pm
Scandoubler in NTSC is broken. So, make sure you switched scandoubler OFF till i fix it.
If scandoubler is OFF, then HSync provides composite sync, while VSync is always 1 - this is standard for RGBS TV output.
So if your monitor requires RGBHV, it won't work.
ericgus
Postby ericgus » Thu May 26, 2016 9:54 pm
Sorgelig wrote:Scandoubler in NTSC is broken. So, make sure you switched scandoubler OFF till i fix it.
As you can see.. I most certainly have it off .. :-)
btw Till said he contacted Peter Wendrich .. who I guess owns the source for fpga64 and hopefully things should become easier for you..
Postby Sorgelig » Thu May 26, 2016 10:18 pm
ericgus wrote:btw Till said he contacted Peter Wendrich .. who I guess owns the source for fpga64 and hopefully things should become easier for you..
Author of FPGA64 were contacted many times already. He simply ignores e-mails. I don't think it will be changed.
Postby Sorgelig » Thu May 26, 2016 10:36 pm
Update:
- Fix scandoubler.
- Better video centering (well, at least for my TV).
C64_mist_20160527.zip
duhproject
Postby duhproject » Thu May 26, 2016 10:47 pm
Sorgelig wrote:Update:
- Fix scandoubler.
You're the MAN! Seems to work here on first boot. Will test, but so far it's working well. Thanks!!!!
duhproject
Postby duhproject » Thu May 26, 2016 10:51 pm
So far, I have tested four games and it works brilliantly. Even switching between PAL and NTSC real time works (like in old cores). Looks like a winner!
duhproject
Postby duhproject » Thu May 26, 2016 11:41 pm
Got the JiffyDOS working, too. This core is working like a dream. Well done, Sorgelig!
ericgus
Postby ericgus » Thu May 26, 2016 11:53 pm
Thats depressing to hear.. Hopefull Til can "nudge" him into action.. I have faith.
vebxenon
Postby vebxenon » Thu May 26, 2016 11:56 pm
Newsdee wrote:For those (like me) that forgot their DOS commands :D
copy /b basic.901226-01.bin + JiffyDOS_C64.bin + JiffyDOS_C1541.bin C64.ROM
Thanks very much :) :D :cheers:
- Atari Jr 2600 clone
- Atari 7800 Peritel
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
vebxenon
- Fix scandoubler.
Thanks again!! :cheers:
- Atari XEGS
- Atari Lynx II
- Atari Jaguar
- MiST Board
ericgus
Postby ericgus » Thu May 26, 2016 11:58 pm
Everything working!!..
My god Sorgelig you are one amazing person! .. I wish I could at least buy you a beer (or wine if thats your preference) for fixing the NTSC, SID and 1541 issues with this core..
ericgus
Postby ericgus » Fri May 27, 2016 12:07 am
One thing I did notice is disks still seem to be write-protected .. any way to change that?
"reset" also seems to keep the last loaded program in memory ... doesnt seem to reset the computer. Though that might only be a quirk if there is a disk error (eg from my disk write test) .. I was using Easy Script and attempted a disk write (save file to disk) .. then tried to reset the fpga64 which just seemed to restart into easy script.. Ill keep checking and see if I can locked down the sequence that does it.
NML32
Postby NML32 » Fri May 27, 2016 2:12 am
Thanks for fixing the NTSC bug it's working great on my setup.
Postby Sorgelig » Fri May 27, 2016 3:59 am
I'm not sure if writing is supposed to be working.
Yes, there is a strange behavior of C64 core after reset. It look like firmware doesn't clean the memory at startup and thus stuck at boot after some games. I've no idea why this happens. And it was always this way since first version for MiST.
There is workaround for this: use my Menu core as startup core. While running, it clean the memory. So, if you run C64 core after Menu core, it will get clean memory.
mambrino
Postby mambrino » Fri May 27, 2016 5:30 am
- Fix scandoubler.
wow!...tested NTSC mode and image centering. Disk writing still not working but other features works flawlessly. Thanks again Sorgelig ;)
ericgus
Postby ericgus » Fri May 27, 2016 5:49 am
I noticed another weird anomaly and it might be related to the MiST's firmware itself and not the c64 core .. but I for the life of me can not find the "plus" "+" key .. there are two equals keys "=" ...
When I get the chance I will try older cores / older firmwares and see if the missing + key shows up..
ericgus
Postby ericgus » Fri May 27, 2016 5:51 am
Sorgelig wrote:I'm not sure if writing is supposed to be working.
I want to say it was disabled on purpose since the previous developer had not worked out the 1541 routines (or had just enabled them) .. I've lost track of that bit and I am trying to find it again .. I didnt know if it was obvious in the code base you are working from if it was something that could be undone or not..
ericgus
Postby ericgus » Fri May 27, 2016 5:56 am
goran wrote:And just to answer the question from the first post: "We Are Demo [2016]" is working perfectly with latest core. :)
EDIT: demo loader doesn't detect disk image change so it doesn't proceed after the "TURN DISK" part.
I have been looking into this issue .. and I think it might be related to the demo itself.. even people with REAL c64's and 1541UII's complain that some loaders built into demos have problems with those devices and do this same sort of thing .. so this could be a coding issue with the demo loader routines itself.
Postby Sorgelig » Fri May 27, 2016 7:24 am
ericgus wrote:but I for the life of me can not find the "plus" "+" key ..
on F10 ;)
ericgus
Postby ericgus » Fri May 27, 2016 7:50 am
on F10 ;)
HA! .. thanks!
