[SOLVED] SuperVidel's DVI connector's screws
Moderators: Mug UK, [ProToS], lp, moondog/.tSCc., instream, Moderator Team, Nature
Postby mikro » Thu Jul 13, 2017 5:30 am
maybe this is really a dumb question but I couldn't overlook that standard DVI male connector is possible to plug (of course) but not possible to fasten -- it seems like on the SuperVidel's female connector there are just holes but not for screws? Does anybody know a way to fix it (other than unsolder the connector...)
Re: SuperVidel's DVI connector's screws
Postby mikro » Fri Jul 14, 2017 7:35 am
Nobody has ever wanted to tighten the connector, only me? Tsk tsk tsk. ;)
calimero
Postby calimero » Fri Jul 14, 2017 11:30 am
Postby mikro » Fri Jul 14, 2017 11:47 pm
Calimero: although it doesn't answer my screws question, what a novel idea with the power switch hole! But how did you fix the VGA connector to the case?
Postby mikro » Sat Aug 12, 2017 2:36 am
It really was a dumb question. The solution is more straightforward than I thought:
i.e. just buy any generic DSUB socket screws and that's it.
Return to “SuperVidel”
