Svethlana and Easymint (Mint 1.18.0)???
MacFalcon
Postby MacFalcon » Tue Apr 22, 2014 3:55 pm
After I finally installed my supervidel hardwarewise and it worked like a charm under TOS, I now did install the svethlana and easymint. I used latest easymint what gave me mint 1.18 and latest driver from nature homepage. I have no networking, neither with DHCP nor with manual configuration. With dhcp I won´t get an IP, with manual config I cannot do any networkung... But the svethlana seems to be there and when I try to ping my router the svethlana led will start blinking... But more I cannot do...
Any suggestions?
Best regards,
Chris
Falcon060, 100/25 MHz, 256 MB SD-RAM, PhantomPBS, CTPCI with Radeon, USB and Network Card. atari rulez!
calimero
Re: Svethlana and Easymint (Mint 1.18.0)???
Postby calimero » Wed Jun 18, 2014 7:06 pm
I have opposite problem: Svethlana work in MiNT but not in plain TOS! :D
check what driver you use in MiNT. I use:
ETHERNAT.XIF 6847 bytes in MiNT\XIF folder (it works fine)
and for plain TOS:
ENEC6.STX 5433 in STING folder - but it wont work! :(
instream
Postby instream » Thu Jun 19, 2014 9:35 am
calimero wrote:Hi,
and for plain TOS:
The Ethernat XIF has nothing to do with the Svethlana. You must have renamed the Svethlana XIF file to make that work. :wink:
And no driver exists for Sting/TOS for the Svethlana. Looks like you are trying to use an ethernec driver. It has nothing to do with the Svethlana either. :wink:
calimero
Postby calimero » Thu Jun 19, 2014 9:43 am
instream wrote:
calimero wrote:Hi,
and for plain TOS:
lol!
and still, svethlana works in my MiNT setup... :) I forgot how I do install it, maybe somewhere else I have right driver :) (I use before NetUSbee for LAN...)
regarding Sting: are there any plans in future to support Sting?
MacFalcon
Postby MacFalcon » Thu Dec 24, 2015 11:42 am
Okay, I now have that error again with mint 1.19... With 1.16 svethlana worked fine... Any suggestions?
Merry Christmas anyway!
Chris
instream
Postby instream » Fri Jan 01, 2016 4:10 pm
There must be some API change then in the XIF interface from 1.16/1.17 (under 1.17 the old svethlana.xif works fine for me) and 1.18/1.19. A recompilation of the freemint code package to get a new svethlana.xif might be needed. There are others on this forum who have much greater knowledge of the freemint and XIF source code tree than I have.
MacFalcon
Postby MacFalcon » Thu Jan 07, 2016 11:23 pm
Maybe I should try posting this to the mint mailing list...
Best regards and thanks for the reply!
Chris
Return to “SuperVidel”
