svupd005.app crashes with Access Fault
alanh
Postby alanh » Sun Sep 08, 2013 2:41 pm
Anyone else get this in 060 mode ?
Not sure if my SuperVidel is already at 005 or not but thought I'd give this a try.
instream
Re: svupd005.app crashes with Access Fault
Postby instream » Sun Sep 08, 2013 7:52 pm
Does the SV still work after this happens?
Did you run it in TOS or Mint?
When does it crash?
alanh
Postby alanh » Sun Sep 08, 2013 8:00 pm
Just booted to TOS, no MiNT at all.
Double click the APP, and it appears to crash when it's finished loading, so expecting it to start executing the APP.
The whole machine is then dead as it displays the Access Fault message with a full dump.
instream
Postby instream » Sun Sep 08, 2013 8:04 pm
Sounds like the app has been corrupted when you downloaded it.
alanh
Postby alanh » Sun Sep 08, 2013 8:06 pm
Don't think so, just downloaded it again, same file size and same md5sum.
1180165 bytes
c4f232e2a71d3e900af93fbdab4df31b
instream
Postby instream » Sun Sep 08, 2013 8:27 pm
I just tried downloading the app using netsurf 2.9 in mint 1.17.0, then set the flags using chmod 755, then ran it from conholio. It started ok.
alanh
Postby alanh » Sun Sep 08, 2013 8:34 pm
Do I need MiNT ?
Can you try it from plain TOS ?
saulot
Postby saulot » Sun Sep 08, 2013 8:37 pm
i've updated everything under tos 1.03c, no problems at all.
alanh
Postby alanh » Sun Sep 08, 2013 8:52 pm
I also have CTPCI installed. Can that cause problems ?
instream
Postby instream » Mon Sep 09, 2013 3:49 pm
It works from TOS too. I can't test with a CTPCI, but you should make sure your CT60 ABE and SDR FW are the latest. If the CTPCI is inactive I guess there should be no problem with svup005.app.
alanh
Postby alanh » Mon Sep 09, 2013 3:53 pm
ABE & SDR are the latest. Sometimes it just hangs after loading and the mouse freezes.
alanh
Postby alanh » Mon Sep 09, 2013 4:09 pm
I can run the APP in 030 mode, but obviously it doesn't detect the SV then.
instream
Postby instream » Mon Sep 09, 2013 7:27 pm
Don't try to update the SV from 030-mode. Some people have bricked their SV that way. Then you need a JTAG cable.
alanh
Postby alanh » Mon Sep 09, 2013 7:28 pm
I know, but just saying that it runs in 030 mode, so the APP checksum is o.k. and it executes. But crashes in 060 mode.
Just a side note, that maybe the APP should exit if it detects 030 mode so people can't brick their SV's.
instream
Postby instream » Tue Sep 10, 2013 5:04 pm
Yes, absolutely. Haven't got around to it yet. :)
Postby shoggoth » Wed Sep 11, 2013 8:14 am
/PeP bitchslaps Hencox and InSTream :)
alanh
Postby alanh » Fri Sep 13, 2013 1:28 pm
Now that I'm back to 1.03 (see speckles on output post), this now works :-)
instream
Postby instream » Fri Sep 13, 2013 5:28 pm
Great! :)
Then we may also need to add a check in svupdXXX.app that the CT60 TOS version should be 1.03 or 2.01.
Return to “SuperVidel”
